07-30-2009, 23:02 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: world wide
Member: 57836 Status: Offline Thanks Meter: 47 | 2600c-1 error in connection i got a nokia 2600c with broking lcd, after changing it, i found problem with it, the signal is quite good, some times drop one or tow or three levels, (but still exist) allmost time the signal is full, but but 75% of times cant make or recives call, whene try to make a call it shows "error in connection" well, after 5 or 6 trys it can make a call, but allmost times it cant, as i observed the the board of the the phone become hot (not very ) exactly under the keypad place and after three or four hours the light of the keypad doesn't turn off, i did the possible i can, i did not find any solution any body can help thanks |
01-13-2010, 05:41 | #2 (permalink) | |
Crazy Poster Join Date: Aug 2008
Member: 831107 Status: Offline Thanks Meter: 6 | Quote:
01-13-2010, 05:49 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | 1st change battery if work then tight the battery terminols.... if not solve then rehot or replace PA and tx filter.... if still not work then read PM..... if not work then rehot RF /UEM /UPP ICs.... |
The Following User Says Thank You to imran zafar For This Useful Post: |
error in connection in nokia sets | HUM | Nokia Hardware & Hardware Repair | 14 | 01-09-2015 07:36 |
2600c unlock error in ub | software.usm | Universalbox | 3 | 05-23-2009 17:06 |
Nec 228.313,616 always Error in connection | Irfangk786 | FuriousGold | 23 | 07-12-2007 14:50 |
Error in connection C2200 in W2000 | foony | VygisToolbox | 2 | 10-10-2005 11:04 |
7200 ( error in connection ) | webmoly | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 06-08-2004 08:52 |
