Old 12-31-2006, 07:48   #1 (permalink)
Member: 216088
Thanks Meter: 43
3120 "5" number key not working. . .
i had nokia 3120 in which 5 number key not working . . . i had clean the phone properly with ipa solution but it didn't work. . .can anybody tell me how to repair it. . .
The Following User Says Thank You to harish35200 For This Useful Post:
Old 12-31-2006, 08:07   #2 (permalink)
rajeshbahri's Avatar
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
SIR PLZ HEAT CPU WITH FLEX OTHERWISE REBALL 100% SURE SOLUTION TESTED BY ME
Old 12-31-2006, 09:05   #3 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
if you trace the keypad track on schematic you will see that the number 5 key will go first to the emf filter (buzzer ic) before it goes directly to the CPU.. try to reheat or replace the filter first..... if no joy.. then you need to reflow UPP or replace otherwise..
wbr...
Old 12-31-2006, 10:15   #4 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 408
cpu..... 11000000000000%
Old 12-31-2006, 13:50   #5 (permalink)
Member: 255625
Thanks Meter: 13
reflow upp 100% prob solve.
abhishekh
Old 12-31-2006, 15:11   #6 (permalink)
Member: 12724
Thanks Meter: 30
There is diffrence between key 5 and other keys of 3120.
All keys are controled by KEYB line.
but col5 ( key 5) by GENIO.
It is 100% UPP problem or PCB problem(track from UPP to key 5)
Old 01-01-2007, 00:38   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
yes 100% upp....!and sometime uem....!
Old 01-01-2007, 10:07   #8 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
100 % cpu problem or the line connected to 5 keyboard. not UEM.
Old 01-01-2007, 10:41   #9 (permalink)
Member: 418843
reball cpu it is 100% solution tested by me many times.
Old 01-01-2007, 16:28   #10 (permalink)
arorasatishkuma's Avatar
Member: 319612
Thanks Meter: 1,452
3120 "5" number Key Solution
Use outer of number "6" & inner of number "8" to have number "5"
Same problem was in my own set
1 Make jumper between outers of Number "5" & Number "6"
2 Cover inner of number "5" with piece of paper
3 Now solder a piece of wire at inner of number "8" & leave other end of
the wire at inner of number"5" This end is not to be soldered,just leave
it on the paper which was used to cover inner of number"5"
Try IT
ENJOY
The Following User Says Thank You to arorasatishkuma For This Useful Post:
Old 01-02-2007, 14:12   #11 (permalink)
Member: 12724
Thanks Meter: 30
arorasatishkuma 's solution is IMPOSSIBLE for 3120.
becuse outers of number 5 is GROUND and if you connect a wire you will lose some other keys for shorting ground!
Just look at attachmnet picture.number 5 in 3120 phones work diffrent .directly from CPU.
It is TRUE for some other models like 2600.but 100% wrong for 3120
Old 01-02-2007, 14:44   #12 (permalink)
Member: 216088
Thanks Meter: 43
so what to do then ?
Old 01-02-2007, 16:26   #13 (permalink)
Member: 319612
Thanks Meter: 1,452
NK_3120---Key"5" not working
Sir as told above I am using this method. Some how it is working.All keys are workig ok.
arorasatishkumar
Ludhiana (PB.)
I am attaching the thumbnail
The Following 2 Users Say Thank You to arorasatishkuma For This Useful Post:
Old 01-02-2007, 16:59   #14 (permalink)
Member: 12724
Thanks Meter: 30
If it is really working I must harvest schematic again.may be there is an unused port on KBLINE
Old 01-02-2007, 21:19   #15 (permalink)
Member: 275631
Thanks Meter: 408
arorasatishkumar
Ludhiana (PB.)
i dont think it should work... coz this solution to 5 will surely efect other keys... they might have some secondry shorting.... its really a bad solution..
why u simply reball cpu.... it works 1000000000000000000%... n the phone doesnt look dirty as urs.... really bad solution....
N86 number 9 & # keys not working SYRYA TEL Nokia Hardware & Hardware Repair 10 03-08-2012 10:07
L7 key number 3 not working vince_07 Motorola Hardware Repair 3 08-02-2009 17:09
6070 menu key not work. change key ic but still not working timopmass Nokia Hardware & Hardware Repair 5 08-10-2008 22:14
v3x number 1 key not working... Mang mel Motorola Hardware Repair 0 03-19-2008 05:54
E900 number keys wont work porn Samsung Hardware Repair 4 08-28-2007 02:14
Page generated in 0.22311 seconds with 10 queries
