Old 06-11-2008, 05:24   #1 (permalink)
Member: 789503
Thanks Meter: 5
Red face 3230 only nokia
3230 only nokia i am doing softewaer &
booting ic change problem is same what cane i do?
The Following User Says Thank You to siraj ali For This Useful Post:
Old 06-11-2008, 05:48   #2 (permalink)
Registered User
Member: 415649
Thanks Meter: 5
Try to change ic zocus.........
Old 06-11-2008, 06:05   #3 (permalink)
Member: 760948
sir try to reheat SRAM
then try to full flash again
The Following User Says Thank You to chikzkee_23 For This Useful Post:
Old 06-11-2008, 06:39   #4 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Did u use SEARCH button. . .?
Old 06-11-2008, 07:05   #5 (permalink)
gsm-world's Avatar
Member: 582790
Thanks Meter: 378
try to flash with new version
Old 06-11-2008, 07:13   #6 (permalink)
Member: 318781
Thanks Meter: 50
dear fellows
do hard format your set
*+3+yes
Old 06-11-2008, 07:13   #7 (permalink)
Member: 318781
Thanks Meter: 50
dear fellows
*+3+yes+power button
Old 06-11-2008, 07:23   #8 (permalink)
Member: 153030
Thanks Meter: 3
here is solution
just formate it with computer or formate manualy
off your mobile now press * butten + 3 butten + calling butten + on butten it will formate your mobile and it will ok *+3+calling+on
Old 06-14-2008, 17:36   #9 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
its uem man and its glued
Old 06-14-2008, 17:54   #10 (permalink)
JHUN PANABO's Avatar
Member: 785769
Thanks Meter: 138
do erase flash
then full flash
write pm
Old 06-14-2008, 20:13   #11 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
try to format with hand like.........................
Old 06-15-2008, 04:20   #12 (permalink)
Member: 364662
Thanks Meter: 9
First do full erase and flash with latest software do full format , if problem not solved change boot ic, if problem not solved reheat/change RAM
Old 06-15-2008, 07:56   #13 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
First do full erase and flash with latest software do full format , if problem not solved change boot ic, if problem not solved reheat or change ram.............
3230 only nokia mahesh123 Nokia Hardware & Hardware Repair 12 12-18-2009 17:06
3230 stop only nokia suresh_boy04 Nokia Hardware & Hardware Repair 8 08-14-2008 08:05
3230 hang on only nokia boopathyp Nokia Hardware & Hardware Repair 24 04-03-2008 19:40
3230 inti simlock fail+only nokia relish Nokia Hardware & Hardware Repair 4 07-10-2007 07:42
3230 shows only nokia j_prakashh Nokia Hardware & Hardware Repair 10 09-15-2006 12:31
Page generated in 0.29517 seconds with 9 queries
