Old 12-22-2007, 11:05   #1 (permalink)
Member: 60081
Thanks Meter: 9
3230 problem
i have 3230 that accept flash erase but don t power on please help
Old 12-22-2007, 11:15   #2 (permalink)
tabuki's Avatar
Member: 455665
Thanks Meter: 36
check top board or change
Old 12-22-2007, 11:16   #3 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
DOES IT TAKE LOCAL MODE OR NOT.
Old 12-22-2007, 11:57   #4 (permalink)
Member: 60081
Thanks Meter: 9
no local mode but i can read write pm full factory unlock sim
Old 12-22-2007, 12:14   #5 (permalink)
Member: 278058
Thanks Meter: 81
No local mode on phone lcd or even not at interface of any box soft?
Old 12-22-2007, 13:07   #6 (permalink)
Member: 60081
Thanks Meter: 9
the problem is not in the lcd cause at first the was hanging
Old 12-22-2007, 15:35   #7 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
ACCORDING TO U IT HAS NO LOCAL MODE BUT IT WRITES PM AND UI SETTING .IT MEANS IT ALSO SHOWS INFO YES/NO?
Old 12-22-2007, 15:59   #8 (permalink)
Member: 60081
Thanks Meter: 9
yes it shows all info
Old 12-22-2007, 16:01   #9 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
THEN IT ALSO SHOWS CHARGING CHECK FIRST.
Old 12-22-2007, 16:02   #10 (permalink)
Member: 60081
Thanks Meter: 9
no for charging.....
Old 12-22-2007, 16:07   #11 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
INSERT THE BATTERY AND THEN TRY TO ON WITH OUT ATTCHING THE UI BOARD.FOR CHECKING THE VOLTAGES .
Old 12-22-2007, 16:30   #12 (permalink)
Member: 60081
Thanks Meter: 9
the problem was first that the was showing nokia and hang
Old 12-22-2007, 18:14   #13 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
IS IT BEFORE FLASH PROBLEM OR AFTER FLASH PROBLEM.NOKIA ONLY XPLAIN..
Old 12-23-2007, 01:42   #14 (permalink)
Member: 473823
Thanks Meter: 10
dear this problem comes from the front board just try to change then tell me wat was the result
Old 12-23-2007, 19:26   #15 (permalink)
Member: 60081
Thanks Meter: 9
problems comes after flash
Nokia 3230 Problem With Midi supertraz Nokia Digital Core Technology 4 ( DCT-4 ) 0 02-04-2006 00:58
3230 problem in camera Triminity UFS2 + UFS3-Tornadoflasher 10 11-21-2005 11:34
3230 problem gsm st WD2 & APE (Symbian Phones) 4 10-22-2005 08:34
nokia 3230 problem?pls help faizalg WD2 & APE (Symbian Phones) 3 10-12-2005 13:39
Page generated in 0.21223 seconds with 9 queries
