Old 10-14-2004, 15:10   #1 (permalink)
Member: 52884
Thanks Meter: 13
Cool 3310 can't power-on
pls i have the above phone it cannot power-on unless you connect a charger to it.i have change the power switch and also the V202.but still the same.any solution.
Old 10-14-2004, 16:17   #2 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 237
try to change the contacts of batery and clean the board down
regards
Old 10-14-2004, 20:11   #3 (permalink)
Member: 79647
hi
check all tracks than check on banana software by rolis if not on then
work on 26 mhz crystal key pad ic cocont ic hagar ic work step by step set will on { but wash first with patrol or wd 40 or dontknowhat kind of liquid ur using in ur coutry so be careful wash than give lamp heat } and tell me keany is great techer he always help us
Old 10-15-2004, 19:30   #4 (permalink)
Member: 52884
Thanks Meter: 13
Cool
kenny,i have change the battery connector and wash the mother but still the same thing.pls any other solution.
Old 10-16-2004, 08:41   #5 (permalink)
Cat10's Avatar
Member: 42123
Thanks Meter: 2
check the connection beetwen power switch and R224, measure the signal in R224 normal 3V drop 0V when push power switch if this measure no work resolde or change CCONT.
Old 08-26-2005, 15:18   #6 (permalink)
Member: 74258
Thanks Meter: 36
hi guy just chenge the c cont IC 100%
Old 08-26-2005, 15:18   #7 (permalink)
Member: 74258
Thanks Meter: 36
hi guy just chenge the c cont IC 100%,ok .
3110c with power supply, power on is ok. but with battery can't power on. unnang Nokia Hardware & Hardware Repair 16 02-10-2013 13:28
1200/1208 power on in fbus cable but can't power on in battery solution here joauz Nokia Hardware & Hardware Repair 6 12-17-2008 06:29
N-GAGE QD Can't power on whit batt,With UFS power on oke... Mr.XXX Nokia Hardware & Hardware Repair 2 07-18-2006 16:38
3310 can't power on gogomit Nokia Hardware & Hardware Repair 7 12-05-2004 17:13
3310 can't power on Keke Nokia Hardware & Hardware Repair 11 09-08-2002 16:25
Page generated in 0.15264 seconds with 9 queries
