12-01-2004, 17:24 | #1 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Sofia,Bulgaria Age: 47
Member: 13917 Status: Offline Thanks Meter: 14 | 3310 can't power on |
12-01-2004, 23:41 | #2 (permalink) | |
Freak Poster Join Date: May 2002 Location: dubai
Member: 11945 Status: Offline Thanks Meter: 76 | Quote:
if ok make wire between + batt connector and d312. good luck. | |
12-02-2004, 11:00 | #4 (permalink) |
Freak Poster Join Date: Aug 2004 Location: www.Tools4Gsm.com Age: 46
Member: 79725 Status: Offline Thanks Meter: 5 | re :3310 power on hi 1st u have to check volt on the power switch if its around 2.8v. if not u have to check the r402=100 ohm & r224 =10K ohm and the connection between these res. if all ok its pcb fault its the powon under ccount missed thx br |
3110c with power supply, power on is ok. but with battery can't power on. | unnang | Nokia Hardware & Hardware Repair | 16 | 02-10-2013 13:28 |
1200/1208 power on in fbus cable but can't power on in battery solution here | joauz | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 06:29 |
N-GAGE QD Can't power on whit batt,With UFS power on oke... | Mr.XXX | Nokia Hardware & Hardware Repair | 2 | 07-18-2006 16:38 |
3310 can't power-on | buschell | Nokia Hardware & Hardware Repair | 6 | 08-26-2005 15:18 |
3310 can't power on | Keke | Nokia Hardware & Hardware Repair | 11 | 09-08-2002 16:25 |
