09-07-2002, 16:58 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | 3310 can't power on I have 3310 no power. Flash can be update; Phone can charge ; power button replace ; and continuity check on the resistor at the top corner . At this stage i can only count on your help . Cheers for now [email protected] |
09-07-2002, 17:39 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310 can't power on KeKe, Check R224 , it must have 3.7V ! or replace CCONT Willy Quote:
09-07-2002, 23:49 | #5 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Egypt Age: 45
Member: 14194 Status: Offline Thanks Meter: 4 | Hi Keke check if the switch is connected with r402 it's right of the antenna switch out of frame if not connect then mack jumper if connect then check if r402 is connected with v414 in right if not then macke jumper if connected then chang r414 r415 if not then replace ccont goodluck Wesam |
09-08-2002, 12:56 | #6 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | HI to ALL and thanks for yr replies first to wesam R401 and s419 continuity check ok. And R224 replace but still no pwer.When press the switch , Dark line appears at bottom screen and disappears. About replacing the ccont , I haven't got the proper tools for that , don't how to guet one in Cape Town email me if your help me guetting one or is there any other solution than replacing ccont????? [email protected] please help Cheers |
09-08-2002, 13:34 | #7 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | KeKe can you put a battery to this phone , and test what voltage at R224 both side ? other way,, put battery to phone, and give 2.8V high for 1 sec. to Btemp this pin, it can wake up phone too Willy Quote:
09-08-2002, 14:51 | #8 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | cheq the battry connection the problem is on it ... cuz u can charge but u don't have enough power to start up the phone... regards.. to: willy wht u can do if u face a mobile read the flash and accept to yp grad and not power on .. alll i c 's and connection cheked .it s o.k |
09-08-2002, 15:38 | #9 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Raheeeeb, First ,, so hard to understand your meaning, do you ask : some mobile can read /write flash rom ... and accept "yp grad" ---> what is this ? all IC and connection cecked and phone not power on ? if yes,,,i will check BSI and BTEMP resistor ! and also CCONT 32.768 KHz sleep clock ! Willy Quote:
09-08-2002, 15:50 | #10 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | 1- sorry for fast typing it cuz to lose some words 2-yp/grd = up grade i use dejan and win dls in write full flash to the phone it s make full erase and write complete flash test and change ccount all resistors batt. connector .. on/of switch 3- do u think 32 k hz or 26 mhz related to power of / on |
09-08-2002, 16:10 | #11 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Raheeeeb, 32.768K have two wave, one is square and others is alternating wave, if square wave is ok, then you can flash phone,, but if no alternating wave, then it can not power on ! 26Mhz/13Mhz ,, if not supply, , then it will show "serial clock fail" when you use wintesla to flash phone . and,, in some case, that BSI resistor is not good, so CCONT does not know what is type battery installed, or CCONT is one have problem Willy Quote:
09-08-2002, 16:25 | #12 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | u r amazing .... very profissional .. i know uit s not the place but u deserv this ..... with respects ..first time i met real mod. know wht he talks about .. greats from land of secrets and magic and gsm hardware repair too..lol land of pharoe |
3110c with power supply, power on is ok. but with battery can't power on. | unnang | Nokia Hardware & Hardware Repair | 16 | 02-10-2013 13:28 |
1200/1208 power on in fbus cable but can't power on in battery solution here | joauz | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 06:29 |
N-GAGE QD Can't power on whit batt,With UFS power on oke... | Mr.XXX | Nokia Hardware & Hardware Repair | 2 | 07-18-2006 16:38 |
3310 can't power-on | buschell | Nokia Hardware & Hardware Repair | 6 | 08-26-2005 15:18 |
3310 can't power on | gogomit | Nokia Hardware & Hardware Repair | 7 | 12-05-2004 17:13 |
