Old 06-26-2002, 03:27   #1 (permalink)
SE-THAILAND's Avatar
Member: 10084
Thanks Meter: 283
3310 dead after change hagar
hi all
at first my 3310 no network then i change hagar (RF signal procesor N505)now can't power on.i check pin 1 of LCD connector not have 2.8 V. but pin 8 be 2.8 V
please help
Old 06-27-2002, 21:06   #2 (permalink)
Member: 2146
Try with hot air or change POWER MANAGEMENT IC .
Old 06-27-2002, 21:54   #3 (permalink)
Member: 12443
Try to reheat it again......try 2 check if its grounded..
goodluck!!
Old 06-28-2002, 17:44   #4 (permalink)
Member: 10084
Thanks Meter: 283
Thank all for reply
@13061972 .at first it can power on and dead after change hagar.now 5v ok,4.8v ok 2.8v ok. i think CCONT not damage .next where i check?
@ Xtian .where pin short to GND
Old 06-28-2002, 18:46   #5 (permalink)
Member: 6475
Tha Hager Is The Problem
Hager Is Not a Rf Ic's It Provide The 13MHz Clock To The Mad To Work so If You Have Replaced in an Uncorrect method You will lose the 13Mhz and the Phone Will Never Work .
So Try To Change It With New One And Be Carefull .
By
Old 06-28-2002, 19:43   #6 (permalink)
Member: 10084
Thanks Meter: 283
@Mohanad
i must change hagar or clock 13 MHZ ?
how to check clock 13MHZ ?.i not have osiloscope
Old 06-29-2002, 04:27   #7 (permalink)
Member: 6475
Talking it is Hager
The 26 Mhz Generate By VCTCXO , And Hager Divide It By 2 So The Result Is 13 Mhz , So if you Found The 26 Mhz at VCTCXO You Have To Change The hager Ic .
By
Old 06-29-2002, 06:58   #8 (permalink)
Member: 10084
Thanks Meter: 283
@ Mohanad
now clock 26 MHZ ok.i remove hagar to other phone it ok.so hagar not damage.next step?
Old 06-29-2002, 07:04   #9 (permalink)
Member: 6475
Wink What About The Balls
Did You Reballing The Hager Well , be sure that No Short between Any Two Balls.
Old 06-29-2002, 10:13   #10 (permalink)
Member: 10084
Thanks Meter: 283
Unhappy
@ Mohanad
i try reball by new hagar but my phone not wrok yet.please tell me for next step
Old 07-02-2002, 02:12   #11 (permalink)
Member: 10084
Thanks Meter: 283
Unhappy
help
Old 07-08-2002, 04:34   #12 (permalink)
Member: 10084
Thanks Meter: 283
please all. i have 4 phone waiting for solve
Old 07-08-2002, 10:05   #13 (permalink)
bre786's Avatar
Member: 6200
Sonork: 100.33330
Thanks Meter: 66
Hello srtech,
Is it your first time installing balls? If so you must practice first as the ball may not correctly installed. If the balls are ok then check around the components.
br
bre786
Old 07-09-2002, 00:47   #14 (permalink)
Member: 10084
Thanks Meter: 283
@bre786
i ball 3390 and 3210 some 3310 no problem.now i don't khow what component damage but now hagar not damage couse i try remove to other phone no problem.please help step by step for check piont
thank for reply
Old 07-09-2002, 03:04   #15 (permalink)
bre786's Avatar
Member: 6200
Sonork: 100.33330
Thanks Meter: 66
Try to reflow Ccont, may be it already have some dry loos pins. It may have problem while you were replacing Hagar.
If still no success read Service Manual and follow the steps.
Good luck
bre786
Nokia 3310 dead after flashing wrong flash? AFR Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-25-2003 18:47
3310 dead after wrong flash, after buckup it not turn on????? Oleg_ Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-18-2002 12:35
3310 dead after changing leds platte Nokia Hardware & Hardware Repair 3 01-07-2002 03:06
3310 Dead after Unlock then Alive after Upgrade ed2k_7 Nokia Hardware & Hardware Repair 5 11-08-2001 21:21
3310 dead after 1 min. to 2 hr. gsnbhagawan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-06-2001 12:02
Page generated in 0.24964 seconds with 9 queries
