Old 11-09-2001, 13:45   #1 (permalink)
Member: 6472
Post 3210 LCD fadeing
There is a 3210 with LCD that fading awey after some minutes. And come back the contrast with makeing presure on its upper, left-upper side.
I have build in a little pace of paper bettwen the front cover and LCD frame. Its jus longer a little the good operation.
I clean all contacts and refit the metal frame to the LCD, but no succes.
If I put some little glue to between the board 8 conntacts (the contacts on the board will stay free of glue of course) and the rubber connection, is this fixed my problem?<br />Or this phenomena neans that my rubber connectors is wrong that I have to change that insted making glue?
Old 11-09-2001, 21:03   #2 (permalink)
D-Brain's Avatar
Member: 7301
Talking
Change the RUBBER Connector of the display, and all should go ok!
Old 11-10-2001, 13:59   #3 (permalink)
Member: 4274
Thanks Meter: 18
Post
check the LCD first if there's a capacitors (2pcs) underneath (upper right).. If yes, then resolder this capacitors and without a soldering lead (do not prolong the contact of the iron to the capacitor just for a second only)... before heating the contacts of the capacitor put a little pressure on top of it, use a small screw driver (be careful not to slip the capacitor), then after heating up the contacts put some glue or loctite at both sides (not on the contact points)... be careful!!!
Old 11-11-2001, 17:20   #4 (permalink)
Member: 6060
I've reppaired 2 LCDs with hot air!!!<br />One was fadeing and second was totally dead.<br />Thanks for good advice!
Old 11-14-2001, 19:05   #5 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
Cool
try to replace c401 if it still fades tyhen try retouch the 2 capacitors of the lcd.i mean remove them and replace with new ones!i've tried it many times and it works 100%.
<br />-----------------------------------
<br />kick butt first,<br />take names later<br /> <img src="biggrin.gif" border="0">
Old 11-20-2001, 13:39   #6 (permalink)
Member: 6472
Post
Thx all advice,
I solved this problem 1 week before. I changed elastomer. LCD works good now <img src="smile.gif" border="0"> <br />I very very cleaned with rubber and aceton the wrong elastomer, and it get better! So it is OK with both of elastomers!
My first action with glue, hm.. it was a silly thing: LCD showed me nothing, but fortunatelly the aceton-solver helped me <img src="smile.gif" border="0">
Thnx again!
psp 2000 , lcd fade away after few min TRABEL Game Consoles & Mp3/4 , HD players 3 09-08-2009 09:53
E700 LCD Fades m-tek1 Samsung Hardware Repair 1 03-28-2007 09:51
3650 lcd fades and blink GSM_BLUE Nokia Hardware & Hardware Repair 7 10-15-2006 05:28
7250i lcd fades away jab Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-14-2004 14:15
MOT Startac 130 - LCD Fading away... D-Brain Hardware Repair by brands 2 11-16-2001 09:46
Page generated in 0.14699 seconds with 9 queries
