Old 07-28-2003, 21:38   #1 (permalink)
Member: 31014
3310 signal drops every 30 sec,
Hi mates,
I have 3310 which drops signal every 30 sec, I tried almost everything ,When I read the set with eprom tool it shows MS ID error, I tried full flash , Change all the IC's except cpu and charging ic but no use , pls help ...
Old 07-28-2003, 23:59   #2 (permalink)
legija
Guest
Posts: n/a
Member:
RTC crystal.
Or broken track somewhere in PCB.
Old 07-29-2003, 06:44   #3 (permalink)
Member: 13545
Thanks Meter: 2
Or VCO faulty ...
Old 07-29-2003, 07:20   #4 (permalink)
Member: 5992
If you have MSID error then COBBA can be faulty...
Did you replaced COBBA ?
Old 07-29-2003, 13:38   #5 (permalink)
Member: 31014
thanks for the replys....Yes I have tried all this ... But the problem remains...
Old 07-29-2003, 18:09   #6 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Sleep clock for sure...Check B200 (32768kHz) and surrounding components...
Check amplitude and shape of clock if u have oscilloscope...
Vule
Old 07-29-2003, 22:16   #7 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
did Youre prob begins after flashing phone? Try flash it with lower or upper soft version!!! and make full faktory reset. It helps You!!
(some nokia flash wersion have no compatibalety)
Old 07-30-2003, 11:15   #8 (permalink)
Member: 31014
No this problem start from the customer and I have 3 fones with same problem ..No water damge Not fall down and no other previous repair, all clean boards ..one more thing is fone is slow and ring tone too slow .. Any ideas pls ...
Old 07-30-2003, 12:20   #9 (permalink)
Batgoy's Avatar
Member: 3272
Change B200 - 32768kHz crystal....
Old 07-30-2003, 12:35   #10 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
need to change 32. Mhz quarc resonator 100%
Old 08-04-2003, 11:53   #11 (permalink)
Member: 31014
Yes mates, I did it in one set , Change 32. Mhz but two other remain ! thanks a lot for the info ..
1112 imei change No signal off after 30 sec Kamijeeawan Universalbox 18 08-10-2009 07:47
w910i restart every 30 sec SBM-AINBENIAN Universalbox 5 02-12-2009 08:13
8330 signal drop after few secs ... ?? TRABEL LG 4 08-16-2005 23:31
3310- Signal Dropping.... iqballk Nokia Hardware & Hardware Repair 6 09-11-2002 04:15
3310 signals drops and comes back bre786 Nokia Hardware & Hardware Repair 11 09-08-2002 16:38
Page generated in 0.24331 seconds with 9 queries
