Old 06-13-2004, 13:07   #1 (permalink)
Member: 6481
Thanks Meter: 6
3510i Key PAd Problem
it was blinking then power off.. so I flashed it and after that it powers on and work except that keypad has some keys working and other like ( 4 , 5 , * , # , 0 , 7 , 8 , 9 , and yes and no and arrows ) were not working and by
measuring i discovered that there is links that are not exisiting at alla as connecting ground of column or rows together and i discoverd another thing
that when i press yes + up arrow = cancel
and yes + downarrow = 0 and no + right arrow = 4 and so ....so lost keys can be get by comibinations of other not working keys !!!!!!!
any one can help....should i rebuild Key pad matrix as schematic says or is there any IC that is responsible for that????
or it Power IC??? or what.....
The Following User Says Thank You to kingbode For This Useful Post:
Old 06-14-2004, 07:51   #2 (permalink)
Member: 7062
Thanks Meter: 126
flash chip error
1- try to earse flash chip bounds then try to flash it with latest software ..
2- or back up the flash data and chnage it and re write the back up again
Old 06-14-2004, 12:33   #3 (permalink)
Member: 6481
Thanks Meter: 6
are u sure???? I measures by SC and found that there is tracks not connected!!!
Old 06-14-2004, 23:24   #4 (permalink)
Member: 7062
Thanks Meter: 126
i said that from your explaination
i got three of them blinking seem to start but switch of only the screen show the dark blue and faid and then switch off ..
first one i flash it with key pad hang like you said and i made what i told you upgrad it then after two days the customer come back with the first fault blink but no power off so i chnage the flash chip i killed the problem
the next two directly i chnage the flash chip after back up the imie data and all the three customers not came back again
br.,
Old 06-15-2004, 13:05   #5 (permalink)
Member: 6481
Thanks Meter: 6
@Raheeb
1- change not chnage
2- what three ..? do u mean three 3510??
and u said that u changed flash chip!!!!!
and backup imei data and the question is hw to backup imei data and why that???
and you say that u are from cairo ..from where in cairo...contact me ICQ 41314599
I'm from cairo too
Old 06-16-2004, 11:08   #6 (permalink)
Member: 7062
Thanks Meter: 126
backup imie data from flash chip befor you chnage the flash chip if you change it without backup after you ll have imie ????????????????
so i use prodigy -uemtool-back up so its generate data 2 for flash chip in back up folder under file named by the serila number.rpl this for flash chip you can not make back up for the uem data 1 .
then you chnage the flash chip and re write the imie data by same tool
you ll have your original imie ..
br.
Old 06-16-2004, 12:20   #7 (permalink)
Member: 24581
Thanks Meter: 87
Same problem i have before 2 months,wrong flash is used,flash him again but with diferent SW.Beliwe me
Old 06-16-2004, 17:08   #8 (permalink)
Member: 2100
Thanks Meter: 40
this is a in detail explaind problem in service manual for 3510(i)
Check hardware version
Flash newest soft
check emi filter
Old 06-16-2004, 21:09   #9 (permalink)
Member: 6481
Thanks Meter: 6
o thanks for all...............
Old 05-23-2005, 18:07   #10 (permalink)
Member: 55800
Thanks Meter: 9
this problem is exactly like mine ... wat suppost should i flash ??? because i think my 3530 is same with 3510 i flash ....
Old 05-24-2005, 02:15   #11 (permalink)
Member: 16062
try write good pm.
good luck
Old 05-24-2005, 02:29   #12 (permalink)
Member: 55800
Thanks Meter: 9
i have tried to upload 3530 pm but stil the same problem ... do i need to full pm ???
Old 05-24-2005, 15:20   #13 (permalink)
Member: 23752
Thanks Meter: 7
try to upload 3510 pm only, see the difference
Old 05-24-2005, 16:05   #14 (permalink)
s1emens's Avatar
Member: 40602
Thanks Meter: 118
Try to upload older firmware.
BR,
s1emens
Old 05-24-2005, 16:34   #15 (permalink)
mroa's Avatar
Member: 18791
Sonork: 100.1577421
Thanks Meter: 74
I just eapir fev nokie like this whit key pad problem
You have to upload good PM to Your nokia
this two worke perfekt if one not work try second and it will be work
The Following 2 Users Say Thank You to mroa For This Useful Post:
x100 key pad problem SATISH SYSOL Platform 5 05-28-2007 21:29
STH-N375 strange key pad problem Lovelysupercat Samsung Hardware Repair 1 09-20-2005 18:45
m550 sendo key pad problem gbada Various 0 06-24-2005 10:55
Nokia 6600 key pad problem jay8ers Nokia Hardware & Hardware Repair 4 11-22-2004 19:30
GD92 key pad problem acyl2000 Panasonic 4 12-04-2001 13:58
Page generated in 0.21637 seconds with 10 queries
