Old 09-23-2005, 18:05   #1 (permalink)
Member: 182134
Thanks Meter: 16
3650 contact retailer
hi i have 3650 have problem phone start up failed contact retailer.....
i already solved this problem but this time its make me mad......
full earse MCU PPM then write pm with twister and griffin......
all UI setting ok
but format user area give me error
User Area Format Failed
00000000: 00 24 00 C0 05 04 01 C3 .$......
some time format user area ok but ....phone start up faild
it show only nokia logo and restart and again nokia logo and again .......etc
Old 09-23-2005, 20:25   #2 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
do format manually, switch off your phone first, then push *,3, and green button(yes) then switch on your phone, if still, up grade the with the latest firmware
Regards
Old 09-23-2005, 21:23   #3 (permalink)
KhOliO's Avatar
Member: 21732
Sonork: 100.75816
Thanks Meter: 218
updown
dear erase flash with UFS Box
then flash ur phone with v 4.13
then UI setting
formmat ur phone
write pm
it will be ok
if any problem u mast install new windows
may be miss some dll or change ur computer
Old 09-23-2005, 23:07   #4 (permalink)
Member: 182134
Thanks Meter: 16
i aready insatll this 4.13 version bt no result phone is rebooting now... only nokia logo and reboot
Old 09-24-2005, 00:25   #5 (permalink)
KhOliO's Avatar
Member: 21732
Sonork: 100.75816
Thanks Meter: 218
used eraser for griffin
then flash with UFS v 4.13
then formmat
then UI setting
& tell me what happend to u
what vertion u used UFS
Old 09-24-2005, 10:11   #6 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
have you tried flashing it with chinese version if you have done normal flashing? or better use hang up or blinking flash file for griffin. as for twister, if still it wont be ok, erase flase it then flash B.R.
Old 09-24-2005, 23:34   #7 (permalink)
Member: 182134
Thanks Meter: 16
now phoen is start and nokia apear and blink 4 or 5 times then switch off automatically any idea mates..
Old 09-25-2005, 00:13   #8 (permalink)
Member: 77923
Thanks Meter: 4
flash full erase and flash v2.5 an ui setting
Old 09-25-2005, 02:57   #9 (permalink)
Member: 99013
Thanks Meter: 52
Hi Buddy,Your fone has hardware problem.Use your heat gun resolder the memory chips then flash or just do full factory reset.It will work 100%...
Good Luck
Old 09-26-2005, 07:47   #10 (permalink)
Member: 182134
Thanks Meter: 16
which memory chip .... which is in crystal or black...
Old 09-26-2005, 21:29   #11 (permalink)
Member: 184508
me too have same conditon set but it show nokia logo 5 times and then shutdown, and when i put in normal with when conected to twister. it show nokia blink and then at last linning on screen. local mod is ok test mod is ok but faild to enter normal mod i need help.
Old 10-08-2005, 16:13   #12 (permalink)
gsmindia's Avatar
Member: 107636
Thanks Meter: 100
3650 contact retailer ive flashed it and its says imei ---- error help
Old 10-08-2005, 16:50   #13 (permalink)
Member: 161796
dont make hardware repair,its software problem...first erase flash,then write mcu ppm,,format user area,then write good pm.don't make full factory set..whem simlock active,then init simlock..use lower version.
3650 contact retailer tybord Nokia Digital Core Technology 4 ( DCT-4 ) 7 03-20-2005 01:52
help 3650 contact retailer gbada Nokia Multimedia 4 12-14-2004 14:54
after flashing 3650 contact retailer gsm-lord Trisha & Matrix Flasher 4 11-29-2003 06:46
3650 contact retailer GSM RAJ WD2 & APE (Symbian Phones) 12 10-08-2003 10:14
Page generated in 0.17612 seconds with 9 queries
