Old 01-18-2008, 13:05   #1 (permalink)
Member: 652842
Thanks Meter: 9
5200 keypad
5200 nokia calling+menu key not work.
The Following 4 Users Say Thank You to k.krishna For This Useful Post:
Old 01-18-2008, 15:24   #2 (permalink)
Member: 547367
Thanks Meter: 7
try another flex i thnk evrythng wil b ok
The Following 3 Users Say Thank You to hemaida For This Useful Post:
Old 01-22-2008, 18:02   #3 (permalink)
Member: 1155
Thanks Meter: 11
the same problem
100% is from mainboard in my case
any ideeas?
The Following User Says Thank You to DanV For This Useful Post:
Old 01-22-2008, 18:53   #4 (permalink)
Temporary banned !!
Member: 369992
Thanks Meter: 9
5200 keypad problem is mainly due to
1.flex cable...
2.keypad ic...
3.mainboard jeck..
first check with another flex if same problem then change keypad ic... after that change flex connecting jecks....
these solutions will work.... enjoy
The Following User Says Thank You to smartengg For This Useful Post:
Old 01-23-2008, 12:50   #5 (permalink)
Member: 210936
Thanks Meter: 5
the same problem for me
any idea please
Old 01-23-2008, 14:55   #6 (permalink)
Member: 1155
Thanks Meter: 11
resolved !!!!
Replaced keypad IC
Regards,
DanV
Old 01-25-2008, 06:38   #7 (permalink)
Member: 244357
Thanks Meter: 70
90 % you have to change keypad ic.
Old 03-17-2008, 04:42   #8 (permalink)
Member: 459869
Thanks Meter: 47
Exclamation
My 5200 after change flex, keypad ic, ui board also same. all keypad no fuction. anyone face/solve this problem b4? please help!
Old 03-17-2008, 05:06   #9 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
may be side key short
check it
Old 03-17-2008, 05:36   #10 (permalink)
Member: 459869
Thanks Meter: 47
Exclamation
2 pcs side key already removed, still the same. all keypad no fuction only power on/off button can be fuction please help!
Old 03-17-2008, 06:34   #11 (permalink)
ranji's Avatar
Member: 670594
Thanks Meter: 51
dear broter plz check kypd ic n flex n also checck side switches
Old 03-27-2008, 13:52   #12 (permalink)
Member: 244357
Thanks Meter: 70
check side keyas and music key also if not checked it.
The Following User Says Thank You to bhardwajparesh For This Useful Post:
Old 03-27-2008, 14:13   #13 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
HELLO DEAR,..
1.TRY 2 CHANGE THE FLEXIBLE 1ST
2.CHECK THE KEYPAD IC,REPLACED/CHANGE
3.CHECK THE SOCKETCONNECTOR FLEXIBLE AT THE MAIN BOARD AND UPPER BOARD
4.CHECK THE CONNECTOR WAYS FROM MAIN BOARD AND ALSO CHECK THE CONNECTOR WAYS AT UPPER BOARD
AND THIS IS SOME PICTURE 4 U...GOOD LUCK...
joni_yang
The Following 19 Users Say Thank You to joni_yang For This Useful Post:
Old 08-09-2008, 11:56   #14 (permalink)
Member: 47625
Thanks Meter: 12
All the solutions are only lottery
If anyone knows 100% then post it
Old 11-07-2008, 12:43   #15 (permalink)
jakrzys's Avatar
Member: 118554
Thanks Meter: 74
As always in a hurry and doesn't look beautiful, but most importantly that it works
The Following 9 Users Say Thank You to jakrzys For This Useful Post:
Pleaze help...5200 keypad not working eko_java_cell Nokia Hardware & Hardware Repair 10 09-04-2010 16:05
5200 keypad ic jumper .:SARCAR:. Nokia Hardware & Hardware Repair 4 09-22-2009 13:30
5200 keypad error tajinder Nokia Hardware & Hardware Repair 13 10-28-2008 19:55
5200 keypad raj_cxe Nokia Base Band 5 ( BB-5 ) 0 06-11-2008 14:18
5200 keypad leds aldo1978 Nokia Hardware & Hardware Repair 2 09-19-2007 19:21
Page generated in 0.25188 seconds with 10 queries
