Old 11-04-2011, 16:20   #1 (permalink)
Member: 1108823
Thanks Meter: 20
5233 water damage dead
dear members i m new to bb5 hardware so requested please give accurate solutions
i have received a set which was water damaged,i checked battery connector for shorting but there is not any shorting,then i open the set and see there is little water in one or two places,i clean it and check on software,i use cyclone for this, it,s shows this
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing RM-625_40.1.003_prd.core.C00 (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051105
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1E8000011E9700528A1C96801D9A5C3E52E0A62D
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
RM-625_40.1.003_prd.core.C00, Type: Flash Image, Algo: XSR 1.6, BB5
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.24.0, Algo: BB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Processing Flash Image Failed -> CMT Secondary Loader was not accepted (1)
Failed to Process all Image files -> Failed to process RM-625_40.1.003_prd.core.C00
i trying usb flashing but same error
please sir i want to know from where i can start repair
set is tottaly clean
reply soon thanks in advance
Old 11-04-2011, 16:41   #2 (permalink)
bobaly's Avatar
Member: 1291612
Sonork: 100.1625587
Thanks Meter: 98
Brother first check cable if write
Phone in Blk error.
1.Use UFS
2. Check & click skip erase
3. write flash when flashing complete remove skip erase & flashing with usb.
4. if not solw then rehoot flash ic carefully.
I hope your problem 1005 solw
Old 11-04-2011, 16:45   #3 (permalink)
Member: 1108823
Thanks Meter: 20
Originally Posted by bobaly View Post
Brother Phone in Blk error.
1.Use UFS
thanks sir for quick reply,i tried and post result
Old 11-04-2011, 16:57   #4 (permalink)
Member: 1108823
Thanks Meter: 20
Phone in Blk error.
1.Use UFS
sir i tried on ufs with skip erase option but shows this
1ST BOOT : C0,07 [Rm-625] [2.2.0.0]
CMT ASICID: 000000010000022600010006400C192101051105
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT PUBID : 1E8000011E9700528A1C96801D9A5C3E52E0A62D
CMT MODE : 00
CMT HASH : B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROMID : 4B9B75103E691FF8
CMT 1ST Boot OK
Cannot Find KEYS CERT
BAD BOOT
ERR: CMT 2ND Boot File not Found
IMAGE : RM-625_40.1.003_prd.core.C00
Process Failed, Repowering Mobile
sir now what can i do?
Old 11-05-2011, 02:49   #5 (permalink)
bobaly's Avatar
Member: 1291612
Sonork: 100.1625587
Thanks Meter: 98
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT MODE : 00
CMT 1ST Boot OK
BAD BOOT
Check flashing cable, change & try..........
Old 11-06-2011, 07:36   #6 (permalink)
Member: 1108823
Thanks Meter: 20
i buy new cable and also check with a working cable,but same error
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT MODE : 00
CMT 1ST Boot OK
BAD BOOT
Rebooting Mobile
Old 11-06-2011, 12:43   #7 (permalink)
Member: 1108823
Thanks Meter: 20
very depressed,no reply further
Old 11-07-2011, 16:43   #8 (permalink)
Member: 1108823
Thanks Meter: 20
Phone in Blk error.
1.Use UFS
no further reply but at last very thankfull, my problem solved by reball flash ic
thanks
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
water damaged 5110 gsmxc Nokia Hardware & Hardware Repair 5 10-18-2001 16:15
help! Dead 5110 v5.30 aklishin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-04-2001 11:56
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2001 11:59
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
Page generated in 0.20739 seconds with 9 queries
