Old 01-19-2010, 21:09   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::5530xm shortcuts button not work::..
5530xm shortcuts button not work(telephone) & (contacts)
but when open menu from middle button all keys work fine
any solution for this
is this hardware or software
The Following User Says Thank You to HUM For This Useful Post:
Old 01-20-2010, 03:52   #2 (permalink)
Member: 916920
Thanks Meter: 2
me oso face tis problem.
But i think more is software. U can try 1st.
Old 01-20-2010, 06:18   #3 (permalink)
Subhadeep's Avatar
Member: 1207045
Sonork: 100.1617234
Thanks Meter: 58
Change PDA..........................
Old 01-21-2010, 02:48   #4 (permalink)
Member: 916920
Thanks Meter: 2
Really? Subhadeep.
You got try before?
And where is the PDA on the board...?
Old 04-27-2010, 13:07   #5 (permalink)
Member: 149247
Thanks Meter: 14
all key not work in 5530
Old 04-27-2010, 13:15   #6 (permalink)
kaleem munir's Avatar
Member: 720201
Sonork: 100.0000000
Thanks Meter: 643
I was having same problem IN 2 cells after unlockin this phone
i sent bacK to company and got new
but i could not find any solution
Old 05-24-2010, 06:33   #7 (permalink)
Member: 185279
Thanks Meter: 43
Question
I have problem with an 5530.
ONLY END key donīt work, I reflashed and changed Touch Screen, and nothing.
Some idea ?
Old 05-24-2010, 06:36   #8 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
try with new Touch pad...............
Old 05-24-2010, 07:09   #9 (permalink)
Member: 185279
Thanks Meter: 43
Red face
I chaged it, and the problem still, isnīt touch pad problem, only END key donīt work.
I do reflash / full reset and still the problem.
Is a very strange problem, when I press END key, hold and press another key, the other key don't respond, but if I drop END key, the another key respond.
Some idea ?
Old 09-26-2010, 03:26   #10 (permalink)
Member: 248086
Thanks Meter: 22
Some idea ?
up same problem with my 5530 phone is thre any solution now
Old 10-14-2010, 12:32   #11 (permalink)
Member: 84048
Thanks Meter: 27
just flash with latest very 100% solution
Old 04-07-2012, 08:37   #12 (permalink)
DOSTI's Avatar
Member: 446289
Thanks Meter: 106
5530 call & end key not working
i try to change many touchpad and also change conecter and also update bt pro still so pls hellp me
.::6500s upper some keys not work::. singhdeep Nokia Hardware & Hardware Repair 13 11-06-2010 00:43
..::3650 menu key not work::.. HUM Nokia Hardware & Hardware Repair 1 06-21-2009 22:34
..::5310 mic not work::.. HUM Nokia Hardware & Hardware Repair 40 06-11-2009 07:08
..::samsung d820 keypad light not work::.. HUM Samsung Hardware Repair 1 04-11-2008 15:14
Setup for shortcut button on MYX-3 pitone02 ARM9 BASED M62 / M62+ 0 06-09-2003 22:03
Page generated in 0.18181 seconds with 9 queries
