Old 04-10-2007, 05:03   #1 (permalink)
Pulax's Avatar
Member: 463891
Thanks Meter: 2
6020 no backlight ...insert sim
wet unit....dry it thorougly no back light insert sim some keypad not functioning....
Can anyboby give me a good solution..already search the thread none of those help me at all....
Old 04-10-2007, 05:37   #2 (permalink)
Member: 170684
Thanks Meter: 19
you are handset may water log clean the pcb fist
1 for back light change the led ic
2 for key pad change the key pad driver ic
3 for insert sim make jumper setting
you will have good result.
Old 04-10-2007, 05:58   #3 (permalink)
Member: 469717
Thanks Meter: 24
Thumbs up Right brother
you are right sir it may be water damage set
so plz clean pcb and rehot or change sim ic, keypad ic and light ic
Old 04-10-2007, 11:19   #4 (permalink)
Member: 278058
Thanks Meter: 81
Like other members said reheat or change the following IC's (after cleaning the board thoroughly):
Old 04-10-2007, 12:14   #5 (permalink)
Pulax's Avatar
Member: 463891
Thanks Meter: 2
is there a jumper way for the led ic.....
Old 04-10-2007, 13:24   #6 (permalink)
Member: 278058
Thanks Meter: 81
Why making a jumper? You can get that IC from phones linke 1110, 1600, 6070 and lots of models. Or just buy some LED IC's
Old 04-11-2007, 05:20   #7 (permalink)
Pulax's Avatar
Member: 463891
Thanks Meter: 2
Some keys are funtioning ryt now except for 7,8,9 ...already solve the insert sim prob...still no backlight....done the procrdure that u said..other solution...
good luck...
Old 04-11-2007, 08:23   #8 (permalink)
Member: 197915
Thanks Meter: 3
check this
check this i thing your problem is solved
Old 04-11-2007, 12:36   #9 (permalink)
Pulax's Avatar
Member: 463891
Thanks Meter: 2
stil not working other great idea...
thanks for those who have given me solution ...
Old 04-11-2007, 13:50   #10 (permalink)
arsenal's Avatar
Member: 83567
Thanks Meter: 2
Led Ics
Where to get the led ic ,,,apart from taking from another phone .
do u know where this ics are been sold ,,pls share link or addresse
thx
Old 04-11-2007, 15:50   #11 (permalink)
Member: 197915
Thanks Meter: 3
try this display connect led+ & Led - Track blue & red line
i think this is help for you
Old 04-11-2007, 16:19   #12 (permalink)
Member: 278058
Thanks Meter: 81
thx
That depends on where you are from. I am in Jordan and we have couple of distributors. Ask around in your country.
Old 12-08-2008, 04:14   #13 (permalink)
Member: 793717
Thanks Meter: 2
6020 inesrt sim help................................
Old 12-08-2008, 04:52   #14 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
try this . good luck
Old 12-08-2008, 04:54   #15 (permalink)
Member: 903492
Sonork: 1590666
Thanks Meter: 571
6020 insert sim pls NizamSLM Nokia Hardware & Hardware Repair 20 08-16-2010 08:49
Nokia 6020 insert sim AjayBagdia Nokia Hardware & Hardware Repair 0 11-10-2006 07:28
6020 insert sim NizamSLM Nokia Hardware & Hardware Repair 0 07-11-2006 10:31
6020 insert sim card Tetouan Gsm Nokia Hardware & Hardware Repair 13 05-24-2006 07:54
6020 auto off if sim inserted MARKIE41 Nokia Hardware & Hardware Repair 12 05-17-2006 23:00
Page generated in 0.24736 seconds with 10 queries
