Old 06-15-2002, 02:47   #1 (permalink)
Member: 6689
6210&3310 dead but can flash
i have a 6210 & 3310 that are dead but i can read & write flash using rolis can anybody help
Old 06-15-2002, 09:04   #2 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
For everybody!!!
If you can flash your phone but it doesn't turn on your flash IC is defective!!!
Everyday people ask this question. Search previous threads.
Old 06-16-2002, 21:31   #3 (permalink)
epic's Avatar
Member: 10635
Thanks Meter: 10
Originally posted by Hanukkah
For everybody!!!
Vir Agero,
How do you replace Flash IC?? Isn't it there is some sort of clear covering on all 4 sides of the Flash IC, If you try to hot air someone says you might damage the Flash IC?? Any technique you get in replacing them?? Pls post here. Thanks....kabayan
BR,
Epic
Old 06-17-2002, 09:07   #4 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Flash ICs where never underfilled by Nokia, except the flash/ram combo in 82xx. No technique, only practice.
Old 06-22-2002, 06:52   #5 (permalink)
Member: 7155
Dear frind , before you touch the flash ic , chek the hagar ic
If hagar is damaged , there is no power and you can flash the phone
WBR
Old 06-22-2002, 13:44   #6 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Change the 13 mhz.. Then tray ...
if not the hager is problemetic
Check it & replay
Old 06-23-2002, 04:57   #7 (permalink)
Own
Member: 5569
Thanks Meter: 10
Red face 13 mhz
he can flash [13 mhz work] but me seen problem after changed flash new all work [old 1 dammage check by labtools]
Old 06-24-2002, 07:25   #8 (permalink)
Member: 7155
Try to Fexed again , there is no solution , so many teqnitians
cant change this kind of flash ics , this depend on your experiance .
WBR
Osama Alkhoraish
Old 07-01-2002, 12:35   #9 (permalink)
Member: 406
Thanks Meter: 2
i know this sounds obvious but is your battery fully charged????
lots of my friends have had problems trying to fix ocntact service by flashing with nearly flat batteries... result no power up it looks like it flashes ok but won't switch on tried same phone with fully charged battery worked perfect
might work... might not.. worth a try though
SE T100 dead but can flash in Div robba Sony Ericsson Hardware Repair 2 04-07-2004 07:46
t100 dead.. but can flash s4sajii Samsung Hardware Repair 6 02-14-2004 03:44
s35 dead but can flash joe locks x1x to x45/x50 7 09-21-2002 20:05
Page generated in 0.19558 seconds with 9 queries
