08-22-2002, 16:23 | #1 (permalink) |
Freak Poster Join Date: Feb 2001 Location: england
Member: 3348 Status: Offline Thanks Meter: 3 | 6210 - very technical sadly two of the pads on V170 are damadge. i would like to know if i can bridge a small wire (in place of the circuit track) to enable the mbus communication to work again So does anybody know where these two pads lead too/ picture of the problem many thanx [email protected] Last edited by wildwhacker; 08-22-2002 at 19:35. |
08-22-2002, 21:54 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 6210 - very technical Wildwhacker Emifilt V170 use for Mbus and CCCINT (charger control interrupt ) V171 use for FBUS TX and RX ! you can fine it from 5110/6110 phone, "E61" , but size might bigger ! try to connect Mbus to R172 ! willy Quote:
08-22-2002, 22:43 | #3 (permalink) |
Member: 3348 Status: Offline Thanks Meter: 3 | i dont understand i have changed the components even though the two bottom outer pads of v170 are damaged. are you saying to solder a wire from R172 to both of these terminals. many thanx for your reply. much appreciated. [email protected] |
08-22-2002, 23:22 | #4 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Wildwhacker X001 Mbus connector -> V170 -> pull high at R172 -> then go to CCONT , then from CCONT to MCU ! Willy Quote:
08-23-2002, 00:57 | #5 (permalink) |
Member: 3348 Status: Offline Thanks Meter: 3 | @willy many thanx my friend..... fone is fixed, faid calculated and working 100000% on orange it looses network on voda, bt cellnet. but thats life. in your expert opinion. would that be the rx/tx network switch, under the top metal plate just under the infra red? thanx again [email protected] |
08-23-2002, 01:25 | #6 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Wildwhacker, is it 6210 phone fall down ? your 6210 must have one part dead at PA or andtenna Switch , or RX filter ! you can try enable netmoniter, check at test 001 and see what CH is it display ( when you put VODA card) ! then you can try to open that "top metal plate " it is include PA, RX/TX/GSM/DCS antenna switch , and also tx detect , RX SAW...........try to see any fragments in those parts ! you can also check, if that TXVGSM, and TXVPCN supply ok or not ! willy Quote:
08-16-2007, 22:26 | #7 (permalink) |
No Life Poster Join Date: Mar 2005 Location: 262-XX ;-)
Member: 125964 Status: Offline Thanks Meter: 24 | I know, its a very old Threat, but iīve same Problem - canīt connect 6210 with PC to correct FaID (but flashing work fine!) Must i solder a Bridge direct to resistor R172 (blue Line) from MBus connector, or is it enough from MBus to V170 (green Line)? |
NOKIA 6210 signals very weak | Shahrukh | Nokia Hardware & Hardware Repair | 11 | 04-08-2004 01:44 |
Very strange problem with 6210!! | TITI | Nokia Hardware & Hardware Repair | 1 | 05-29-2003 08:09 |
6210 very strange..... | aspog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-29-2002 11:47 |
6210 very, very soft ringing? | sjakie | Nokia Hardware & Hardware Repair | 0 | 09-06-2002 22:59 |
6210 LCD- very dark | andrews | Nokia Hardware & Hardware Repair | 0 | 06-01-2002 14:43 |
