Old 04-10-2007, 13:36   #1 (permalink)
Johnessen's Avatar
Member: 19831
Thanks Meter: 46
6260 not charging
I have 6260 that suddenly stopped charging.I need a solution to this.
Thanks in advance
Old 04-10-2007, 14:13   #2 (permalink)
nycu's Avatar
Member: 194609
Thanks Meter: 46
Didi you check the fuse above the batery conector?
Old 04-10-2007, 20:21   #3 (permalink)
Johnessen's Avatar
Member: 19831
Thanks Meter: 46
How do I know which one is the fuse?,and what should with it.Change it or what?.I saw 3 three things above the charger,one is just black,the other one has black in the middle and silver on both sides while the other one is a little more smaller with K written on it.
Thanks in advance.
Old 04-10-2007, 20:39   #4 (permalink)
Member: 367928
Thanks Meter: 178
yes dear K is fuse, chk all charging component components . for component look at the diagram
Old 04-10-2007, 21:02   #5 (permalink)
Johnessen's Avatar
Member: 19831
Thanks Meter: 46
Thank you very much but what do I check here,if it has a loose contact or test it with multitester to see if it is still good? and where is the diagram?
Old 04-10-2007, 22:57   #6 (permalink)
Member: 372160
Thanks Meter: 11
CHEK ThIS PIC AND reply
pic
Old 04-10-2007, 23:25   #7 (permalink)
Johnessen's Avatar
Member: 19831
Thanks Meter: 46
I followed your pic and everything is fine.I used my multitester and the connection was fine
Old 04-15-2007, 12:25   #8 (permalink)
Member: 367928
Thanks Meter: 178
remove k and short with jumper post result
Old 04-15-2007, 16:47   #9 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
IF it sows directly not charging to a screen than check the pin connectivity and its components related to middle pin of the battery connector
6260 not charging gpong Nokia Hardware & Hardware Repair 1 05-05-2007 10:11
6260 not charging tommy00 Nokia Hardware & Hardware Repair 2 02-04-2007 10:21
nokia 6260 not charging and no network williamvirk Nokia Hardware & Hardware Repair 4 08-15-2006 13:53
6260 not charging mehdi12 Nokia Hardware & Hardware Repair 0 06-15-2006 07:54
6260 not charging... sergo_zmeia Nokia Hardware & Hardware Repair 3 05-30-2005 20:43
Page generated in 0.23023 seconds with 9 queries
