Old 03-23-2007, 08:17   #1 (permalink)
maheshsaiganesh's Avatar
Member: 289913
Thanks Meter: 125
6280 camera opreation failed problem
6280 camera not work opration failed problem i have change flex cable,change camera,change ic N1060 but problem same not solve.
The Following 3 Users Say Thank You to maheshsaiganesh For This Useful Post:
Old 03-23-2007, 11:17   #2 (permalink)
Softway's Avatar
Member: 143889
Sonork: 100.1584685
Thanks Meter: 341
did u try to flash??? try it maybe it will help??
The Following User Says Thank You to Softway For This Useful Post:
Old 03-23-2007, 14:47   #3 (permalink)
Member: 13643
Thanks Meter: 23
Hi ,
Try To Change Keyboard Ui Pwb ( Keyboard Upper Module )
Copernico
The Following User Says Thank You to Copernico For This Useful Post:
Old 04-13-2007, 11:03   #4 (permalink)
Member: 124069
Thanks Meter: 59
6280
origenel Change flex (rubbon), it works 100%
The Following 2 Users Say Thank You to aftab70 For This Useful Post:
Old 04-13-2007, 14:56   #5 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
Hi br frist try this calen the bord 2end cahange cabal probel is not solved change this ics .
..::mr fone::..
The Following 12 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 05-08-2007, 23:29   #6 (permalink)
Member: 228717
Thanks Meter: 28
i have 5 6280 whit camara failed and i try all solutions but problem still same ...and i flash it whit last software 6.10 and nothing
The Following 3 Users Say Thank You to neliocoelho For This Useful Post:
Old 05-16-2007, 06:49   #7 (permalink)
singhdeep's Avatar
Member: 395477
Sonork: 100.1602978
Thanks Meter: 140
plz any one tell em what is flex.plz post with pic
The Following 2 Users Say Thank You to singhdeep For This Useful Post:
Old 05-16-2007, 06:54   #8 (permalink)
singhdeep's Avatar
Member: 395477
Sonork: 100.1602978
Thanks Meter: 140
what is flex where is in d 6280 and how can i change it
thanx
The Following 3 Users Say Thank You to singhdeep For This Useful Post:
Old 05-16-2007, 07:31   #9 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
flex means flat cable which connects the upper(display portion) and lower(engine module) board
The Following 2 Users Say Thank You to reji For This Useful Post:
Old 05-28-2007, 03:27   #10 (permalink)
Member: 79823
Thanks Meter: 26
i have the same problem with 6280 changed the ribon,camera,ic,flashed with 06.10 v,done evry possible things no results,need help on this
thank you
daanish
The Following 2 Users Say Thank You to daanish For This Useful Post:
Old 05-28-2007, 10:44   #11 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
thank you
daanish
Mostly 6280/6288 camera problem come from 2 reasons - one is flat cable ( damage on it stop driving for 1,8 V to low module ) and second one is regulator 2,8 V near to camera socket ( there usualy damage come from water or mechanical damage ) ...
The Following 4 Users Say Thank You to debeliamark For This Useful Post:
Old 05-30-2007, 07:17   #12 (permalink)
NPL2's Avatar
Member: 137782
Thanks Meter: 4
can someone attach again the picture of the ics damaged please.
Can't see them neither download them.
best regards
The Following 2 Users Say Thank You to NPL2 For This Useful Post:
Old 05-31-2007, 15:54   #13 (permalink)
Member: 281239
Thanks Meter: 18
CAN U HELP?6288 WHEN TAKE PHOTO....AFTER CAPTURE......HANG...??????CAN I DO ANYTHINK?
The Following 3 Users Say Thank You to AH KIAT For This Useful Post:
Old 05-31-2007, 15:55   #14 (permalink)
Member: 281239
Thanks Meter: 18
6288 When Take Photo....after Capture......hang...??????can I Do Anythink?
Old 05-31-2007, 15:58   #15 (permalink)
Member: 281239
Thanks Meter: 18
..::mr fone::..
6288 WHEN TAKE PHOTO....AFTER CAPTURE......HANG...??????CAN I DO ANYTHINK?SORRY MY ENGLISH NO GOOD....ANY SOLUTION?
The Following 5 Users Say Thank You to AH KIAT For This Useful Post:
6070 camera opreation failed laddimobile Nokia Hardware & Hardware Repair 1 05-29-2009 07:49
6280 camera video fail operation yus_ys Nokia Base Band 5 ( BB-5 ) 8 03-08-2008 10:03
6280 Camera Operation Failed!!! khem Nokia Base Band 5 ( BB-5 ) 3 07-17-2007 07:46
6280 camera operation fail kelvinlim Nokia Hardware & Hardware Repair 6 07-10-2007 19:33
nokia 6280 camera opreting failed danish_teli Nokia Hardware & Hardware Repair 11 06-04-2007 12:52
Page generated in 0.21099 seconds with 10 queries
