Old 12-08-2006, 13:54   #1 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
6280 Charge Ok But not switching On=???
This 6280 is charging fine but cant power on, i can use Cable to power it up.
Switch ways look fine, flex is Ok.The Top part can switch on with another working board.
Any Idea???
Old 12-08-2006, 15:51   #2 (permalink)
Member: 143810
Thanks Meter: 44
maybe u need to rewrite PM.
Old 12-09-2006, 05:15   #3 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
Any Idea???
Change On-Off Switch...
If Not Ok Then Change Flex Cable
Archit Raj
Old 12-09-2006, 08:12   #4 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
Archit Raj
As I said, the switch button is FINE and FLEX is OK.
That Board cant switch on even if i use a working phone s top part.
That flex works perfect on other board.
Problem is on the mother board.
@tee_beat , no problem of PM or soft problem.
Old 12-09-2006, 08:54   #5 (permalink)
jainmunda's Avatar
Member: 84128
Thanks Meter: 110
change ic under flex connecter 2nd from right.
1000% working
Old 12-09-2006, 15:44   #6 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Wink
try this and post result.......
if not solve by this u have to change crystal ic too or rehot them..
The Following User Says Thank You to shahjee For This Useful Post:
Old 12-11-2006, 18:29   #7 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
The problem here is , there is no POWER on the 5th Pin(Red line from picture).Even if i short it it doesnt power up the phone as that pin is not powered.
Any other idea???
Thanks
Old 12-12-2006, 11:13   #8 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
Is there another Point which has the same value as the Red pin(5th from right down)? I found one, The test point just down the first Glass IC from right, but still doesnt communicate as it s not powered.
Old 04-09-2007, 11:46   #9 (permalink)
Member: 4566
Sonork: 100.112355
Thanks Meter: 503
Any body had success on this problem? How about changing the crystal ic, 2nd from the right?
Old 05-03-2007, 12:58   #10 (permalink)
Member: 197538
Thanks Meter: 97
Yes I successfully changed the crystal IC 2nd from right and its working fine ,, make sure u find a good quality IC to replace or just do jumping to be sure and than look for IC ... ( jumping is same as 6280 or any BB5 Keyad IC )
Mine worked with a charm .. Also if u have problems with black screen change the FM radio UI Driver ( a small IC on the LEFT ) same as Camera IC or FM RAdio IC from any BB5 Phone
thanks
Mike
The Following User Says Thank You to mike67 For This Useful Post:
Old 07-31-2007, 15:27   #11 (permalink)
Member: 110487
Thanks Meter: 52
1000% working
its working for me
thank u
Old 11-30-2007, 13:24   #12 (permalink)
fizzo's Avatar
Member: 53864
Thanks Meter: 7
1000% working
thx working
Old 12-14-2007, 19:35   #13 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
I forgot to report here that the phone worked nice after changing the ic.
tHANKS
Old 12-14-2007, 20:14   #14 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
yes right solution change z3300!!!
File Type: jpg 6280 charging ok but cant power on solution.JPG (170.9 KB, 499 views)
The Following 2 Users Say Thank You to acay For This Useful Post:
Old 12-14-2007, 22:00   #15 (permalink)
Member: 547367
Thanks Meter: 7
thnk u man 4 ur cokuncatng n advices
charging ok....but not switch on... vijay1101 Nokia Base Band 5 ( BB-5 ) 7 10-21-2008 07:58
n 70 charge ok but dosn't switch on nilkamal Nokia Hardware & Hardware Repair 4 06-22-2008 11:19
P910i Charging ok but not switch on ..::Sunil::.. Sony Ericsson Hardware Repair 1 03-10-2007 06:04
N1100, Charge ok but can't switch on haider Nokia Digital Core Technology 4 ( DCT-4 ) 15 02-01-2006 07:44
N1100 charge ok but can't switch on haider Nokia Hardware & Hardware Repair 5 10-10-2004 14:14
Page generated in 0.23362 seconds with 10 queries
