Old 07-26-2008, 14:07   #1 (permalink)
Member: 730882
Thanks Meter: 4
6280 no diplay can hear nokia sound please help
hi
I have nokia 6280 was switch on ok but not come up any thing , can hear nokia sound very clear , the phone was drop very hard , the lcd not break try clean the socket check the flex cable but still unluck , I don't have lcd to test due to not sue so not buy yet, please any solution , thanks in advance
Old 07-26-2008, 14:16   #2 (permalink)
AdickAsia's Avatar
Member: 801083
Thanks Meter: 99
Solution ur problem
1. Check ur LCD -- change again
2. Check ur conector LCD in ur front board -- clean, resolder or change.
3. Check all track ur display conector, if cut -- please jumper
4. Check ur conector falexsible in ur front board -- clean, resolder or change
5. check ur flexible -- clean the conector or change with original flexible (if not original-- change the conector in flexible with original conector)
6. check ur conector flexibel in ur main board -- clean, resolder or change
7. Check track from conector to display IC --- if cut-- jumper
8. Check ur display IC -- reheat, reball or change
good luck
The Following User Says Thank You to AdickAsia For This Useful Post:
Old 07-26-2008, 14:29   #3 (permalink)
AdickAsia's Avatar
Member: 801083
Thanks Meter: 99
Old 07-26-2008, 14:50   #4 (permalink)
Member: 51453
Thanks Meter: 729
change lcd driver.if still the same change c6052
br
Old 07-26-2008, 16:51   #5 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
Originally Posted by chess12 View Post
hi
I have nokia 6280 was switch on ok but not come up any thing , can hear nokia sound very clear , the phone was drop very hard , the lcd not break try clean the socket check the flex cable but still unluck, I don't have lcd to test due to not sue so not buy yet, please any solution , thanks in advance
change the lcd first,then cable and lcd ic's.it will be fine.post result.
nokia 1100 ear piece amming sound please help me prakash40 Nokia Hardware & Hardware Repair 0 09-06-2009 13:13
"" Samsung SGH-E700 no speaker sound - Please help me"" rajeevpchandran Samsung Hardware Repair 0 06-02-2008 12:35
MTBOX NOKIA can not boot any NOKIA phones!!! Please help! hoang MT-BOX 6 11-23-2007 00:31
W200i speaker Humming sound Please help kum Sony Ericsson Hardware Repair 2 10-22-2007 06:11
1600 I can hear the sound but.........No ring amol_sm Nokia Digital Core Technology 4 ( DCT-4 ) 4 10-22-2006 02:10
Page generated in 0.14921 seconds with 9 queries
