02-24-2007, 08:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | MTBOX NOKIA can not boot any NOKIA phones!!! Please help! I tried change other adaptor from other working MTBOX but no luck! How can solve this problem? |
02-24-2007, 08:59 | #3 (permalink) |
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | This is: --------------------------------------------------- MTBOX: xxxxxxxx - Nokia Flash/Repair v1.29.5 Box: CR V 1.001 256 Code: NK V 1.001 1044 SN: xxxxxxxx Nokia Unlimited: 163 times started SonyEricsson Trial: 10 left, each max 15min ============= Set Flash mode for info ============= Pins: Mbus 0, Box Tx 1, Box Rx 0, Bsi 0 Boot... Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit ============= Set FBus mode for info ============= Pins: Mbus 0, Box Tx 1, Box Rx 0, Bsi 0 -------------------------------------------------------------------- tested many phone but same problem, other MTBOX works normally with those phones! |
02-24-2007, 09:27 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | check the RJ48 connector of ur mt-box,, both the corner pins of the 10 pins must be having some problem.. just pull them both up with the help of twezers. this is normal problem as u must inserted a normal 8 pin rj45 cable into the connector by mistake. |
11-23-2007, 00:31 | #7 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Pampas Gaúcho tchê Age: 48
Member: 116335 Status: Offline Thanks Meter: 17 | Quote:
I've having this problem too and I solved with Your post. Thanks a lot | |
2x D900i fail flashing, first not booting, now no network....please help. | Jazz | NSPRO | 1 | 06-18-2009 04:35 |
can not flash any chines phone | bhardwajparesh | Infinity-Box | 1 | 01-20-2009 18:56 |
mt box can not boot any mobile | syrian | MT-BOX | 6 | 06-22-2008 08:14 |
I can not flash any Nokia Phone of the dct3 and dct4 series.... | klaus4 | Twisterflasher | 1 | 03-21-2005 00:36 |
