Old 02-13-2012, 11:29   #1 (permalink)
Dipankor-ctg's Avatar
Member: 1541551
Sonork: +965 99095810
Thanks Meter: 4,698
Nokia Asha 200 support Br Dipankor-ctg
Dipankor-ctg
The Following 4 Users Say Thank You to Dipankor-ctg For This Useful Post:
Old 02-13-2012, 11:31   #2 (permalink)
Member: 1541551
Thanks Meter: 4,698
Keys and parts
  • 1 — Charger connector
  • 2 — Earpiece
  • 3 — Screen
  • 4 — Selection keys
  • 5 — SIM manager key
  • 6 — Call key
  • 7 — Keypad
  • 8 — Microphone
  • 9 — Headset connector/Nokia AV connector (3.5 mm)
  • 10 — Micro-USB connector
  • 11 — Wrist strap hole
  • 12 — Messaging key
  • 13 — End/Power key
  • 14 — Navi key (scroll key)
Dipankor-ctg
Old 02-13-2012, 11:32   #3 (permalink)
Member: 1541551
Thanks Meter: 4,698
  • 15 — Camera lens
  • 16 — Loudspeaker
  • 17 — Memory card slot
  • 18 — SIM card slot (SIM 2)
Dipankor-ctg
Old 02-13-2012, 11:33   #4 (permalink)
Member: 1541551
Thanks Meter: 4,698
Insert a SIM card and battery
This phone is intended for use with a BL-5J battery. Always use original Nokia batteries.
If you only have one SIM card, insert the card into the internal SIM card holder.
  1. Place your finger in the recess at the bottom of the phone, and carefully lift and remove the back cover.
  1. If the battery is inserted, lift it out.
  2. Slide the SIM card holder to unlock it (1), and use your fingernail to lift it. Make sure the contact area would face down when the SIM card holder is lowered (2), insert the SIM card into the holder, and lower the holder (3). Slide the card holder to lock it (4).
  3. Line up the contacts of the battery and the battery compartment, and insert the battery. To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place
Dipankor-ctg
The Following User Says Thank You to Dipankor-ctg For This Useful Post:
Old 02-13-2012, 11:35   #5 (permalink)
Member: 1541551
Thanks Meter: 4,698
Insert a second SIM card
  1. Open the cover of the external SIM card slot, marked with .
  2. Make sure the contact area of the SIM card is facing up, and insert the card. Push the card in, until it locks into place.
  3. Close the cover.
Remove the second SIM card
Dipankor-ctg
Old 02-13-2012, 11:36   #6 (permalink)
Member: 1541551
Thanks Meter: 4,698
Charge the battery
Your battery has been partially charged at the factory, but you may need to recharge it before you can switch on your phone for the first time. If the phone indicates a low charge, do the following:
  1. Connect the charger to a wall outlet.
  2. Connect the charger to the phone.
  3. When the phone indicates a full charge, disconnect the charger from the phone, then from the wall outlet.
You do not need to charge the battery for a specific length of time, and you can use the phone while it is charging.
If the battery is completely discharged, it may take several minutes before the charging indicator is displayed or before any calls can be made.
If the battery has not been used for a long time, to begin charging, you may need to connect the charger, then disconnect and reconnect it.
Dipankor-ctg
Old 02-13-2012, 11:38   #7 (permalink)
Member: 1541551
Thanks Meter: 4,698
Switch the phone on or off
Press and hold the power key until the phone vibrates.
You may be prompted to get the configuration settings from your network service provider. For more information on this network service, contact your network service provider.
Dipankor-ctg
The Following 2 Users Say Thank You to Dipankor-ctg For This Useful Post:
Old 02-13-2012, 11:40   #8 (permalink)
Member: 1541551
Thanks Meter: 4,698
Insert a memory card
Use only compatible memory cards approved by Nokia for use with this device. Incompatible cards may damage the card and the device and corrupt data stored on the card.
Your phone supports memory cards with a capacity of up to 32 GB.
  1. Open the cover of the memory card slot.
  2. Make sure the contact area of the memory card is facing up, and insert the card. Push the card in, until it locks into place.
  3. Close the cover of the memory card slot.
Important: Do not remove the memory card when an application is using it. Doing so may damage the memory card and the device and corrupt data stored on the card.
You can remove or replace the memory card without switching the phone off.
Remove the memory cardPush the card in, until it is released, and pull the card out.
Dipankor-ctg
Old 02-13-2012, 11:40   #9 (permalink)
Member: 1541551
Thanks Meter: 4,698
GSM antenna
The antenna area is highlighted.
Avoid touching the antenna area while the antenna is in use. Contact with antennas affects the communication quality and may reduce battery life due to higher power level during operation.
Dipankor-ctg
Old 02-13-2012, 11:41   #10 (permalink)
Member: 1541551
Thanks Meter: 4,698
Connect a headset
Do not connect products that create an output signal, as this may damage the device. Do not connect any voltage source to the Nokia AV connector. If you connect an external device or headset, other than those approved by Nokia for use with this device, to the Nokia AV connector, pay special attention to volume levels.
Dipankor-ctg
Old 02-13-2012, 11:42   #11 (permalink)
Member: 1541551
Thanks Meter: 4,698
Attach the wrist strap
Remove the back cover, thread the strap through the hole, and loop the strap around the wrist strap peg.
Wrist straps may be available separately.
Dipankor-ctg
Old 02-13-2012, 11:45   #12 (permalink)
Member: 1541551
Thanks Meter: 4,698
Hardware-Repair Area
Wait And See Full Hardware Repair & Solution Come in
HARDWARE Team Bangladesh
Dipankor-ctg
The Following 3 Users Say Thank You to Dipankor-ctg For This Useful Post:
Old 02-14-2012, 08:37   #13 (permalink)
Member: 623831
Sonork: 100.1609055
Thanks Meter: 5
plz help me Initializing...
DA_LIB_VER_3.9.0.0
It is sensing the pinout fast...
RXD=6 TXD=7
Connecting...
Connected...sending boot...
FDL test...OK
ArmBootMode: 6600700100026A00_01
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 115200 is ok
Reading phone HW info...
Manufacturer: ST & NUMONYX, Device: Unknow
CPU: SC6600L2 Flash: NOR_UNKNOWN
Old 02-14-2012, 18:26   #14 (permalink)
Member: 1541551
Thanks Meter: 4,698
DA_LIB_VER_3.9.0.0
RXD=6 TXD=7
Connecting...
FDL test...OK
Done.
Done.
you post wring write Section post now
Old 03-06-2012, 14:39   #15 (permalink)
mj_0990's Avatar
Member: 306026
Thanks Meter: 111
please solution for asha 200 hang and restart
flash done with atf but still hang and restart
maybe it is hardware problem
Page generated in 0.33224 seconds with 9 queries
