Old 10-13-2009, 05:01   #1 (permalink)
.::PATEL TELECOM::.'s Avatar
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
nokia 2600c & 2630 keyped problem
hello
i have nokia 2600 & 2630 pcs witch have problem keypad not working
1) i change keypad strip
2) i change keypad ic(og from working 2626 )
3) i reball cpu
4) check all track between ic to keypad socket all is ok
but no work keypad
and i also make self test it show keypad stuck = failed
i cant understand where is problem
i try all thing but no result
please help me for solving this problem
thanking you
Patel telecom
The Following User Says Thank You to .::PATEL TELECOM::. For This Useful Post:
Old 10-13-2009, 05:11   #2 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
dear friend change cpu this is cpu problem i m sure
Old 10-13-2009, 05:23   #3 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
ok witch cpu i use can i use 2626,1200,1600 cpu???????????
Old 10-13-2009, 05:36   #4 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Thanks Meter: 99
i dont think it is cpu problem may be faulty connector
Old 10-13-2009, 08:34   #5 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
but friend i check lin from conector to flex all is ok
Old 10-13-2009, 09:02   #6 (permalink)
Member: 216690
Thanks Meter: 53
if the buttons cant executed. use two finger method
need two hands to operate the phone
heres is the simple trick
1 GO TO
hold press GO TO then MENU (middle)
2 BACK or CANCEL
hold press BACK or CANCEL then CALL BUTTON (color green)
3 UP BUTTON
hold press UP BUTTON then RIGHT BUTTON
4 DOWN BUTTON
hold press DOWN BUTTON then RIGHT BUTTON
BTW
THE ONLY SOLUTION TO FIX THIS PROBLEM IS.....
REPLACE UPP..... thanks for reading.....
File Type: rar 2630 2600 keypad .rar (351 Bytes, 773 views)
The Following 5 Users Say Thank You to airchiew For This Useful Post:
Old 10-13-2009, 15:37   #7 (permalink)
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,488
its totaly cpu fault....
use same nomber cpu..
and change it...
Old 10-13-2009, 17:28   #8 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
use 2630 cpu i hope it will be same as 2600c..
Old 10-13-2009, 19:48   #9 (permalink)
Member: 1126612
Sonork: 1212
Thanks Meter: 2
thank u very much@@@@@@@@@@@@@@@@@@@@@@@@@@@
Old 10-14-2009, 08:50   #10 (permalink)
Member: 158032
Thanks Meter: 331
Bro if u like the post then only press thanks button that's all...
The Following User Says Thank You to ..::My3gtech::.. For This Useful Post:
Old 10-14-2009, 09:39   #11 (permalink)
Member: 197720
Thanks Meter: 24
i have two pieces few days ago i tried everything i could refused to work have to soak it in petrol for one day then dried under 200 watt bulb the two are now functional
Old 10-14-2009, 09:43   #12 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
ha ha ha very funny trick
u change ic,socket etc???????? but same problem ??? than put in petrol????
ok thanks for give trick thank you very much
Old 10-14-2009, 09:52   #13 (permalink)
Member: 1081011
Sonork: 100.1594100
Thanks Meter: 463
brother check this............
The Following User Says Thank You to .::ADNAN440::. For This Useful Post:
Old 10-14-2009, 10:16   #14 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
my friend i do all thing
but no result
read my first post
Old 11-15-2009, 03:04   #15 (permalink)
samibapy's Avatar
Member: 325816
Thanks Meter: 31
check the camera button and volume keys also ( if there r)
nokia 2600c and 2630 files ashaka Nokia Digital Core Technology 4 ( DCT-4 ) 2 06-18-2008 04:53
How to unlock Nokia 2760 & 2630 brijmehta1 MT-BOX 9 05-27-2008 09:57
New Nokia 1650 & 2630 Mobile MB Here R@ZIB-BD Java, iOS, Android, Symbian development 6 04-22-2008 18:42
New Products: Nokia 6267 & 2630 Jaf Cable; Archer Sam Clip;Samsung E210 unibox cable. Tele-way Main Sales Section 0 09-21-2007 10:04
Page generated in 0.21931 seconds with 10 queries
