08-27-2004, 16:09 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Location: nederland Age: 52
Member: 24929 Status: Offline Thanks Meter: 7 | 6310i problem after flash |
08-28-2004, 15:06 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | try to check your flash ic or replace it after replacing try to rebuild your imei coz it will be ?????????? ,after rebuilding you could have your phone working normaly |
08-28-2004, 22:16 | #3 (permalink) |
Member: 24929 Status: Offline Thanks Meter: 7 | rebuild your imei ??? must i change uem? i think thats not the problem, imei are not ??????? and the phone works before flashing, someone else a solution? |
08-29-2004, 09:01 | #5 (permalink) |
Member: 24929 Status: Offline Thanks Meter: 7 | ok tell me where is the hagar, 6310i has no hagar tony montana, change flash ic is a big problem for me, always trouble if i do that, i rehot mjoelner, flash ic but same problem, and now? |
08-30-2004, 08:41 | #7 (permalink) |
No Life Poster Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | @gsm style i will tell you something important for 6310i!!!!!!!!!!!!!! another time when you have 6310i.. you must see better the bloototh works or not ?(freeze) becouse if not works (when your phone is on ) after one flash the phone must be off (like yours )its 100%tested. and your solution now is if you have another 6310i dead you must change the bloototh ic in the pcb and reflash the phone must be 100% ok i dont know if you understand me ?? best regards keany |
08-30-2004, 18:45 | #8 (permalink) |
Member: 24929 Status: Offline Thanks Meter: 7 | i understand you, don't now or the bleutooth works from this 6310i, i have an other 6310i dead, must i change the whole thing just like at the picture? |
6310i dead after flash | mixone | Griffin | 0 | 07-24-2005 16:35 |
Nokia 6310i dead after flashing with Griffin | Icaros | Griffin | 5 | 01-27-2005 16:26 |
working 6310i DIES after flash with ufs2 | mohammed | UFS2 + UFS3-Tornadoflasher | 2 | 05-03-2004 20:00 |
Nokia 6310i - dead after flashing | Pumpstyler | Griffin | 4 | 01-20-2004 13:15 |
