Old 09-11-2004, 07:10   #1 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
6600 joystick problem
i can't move at left on joystick.can some one give me diagram for keypad or joystick.help me please....
Old 09-11-2004, 22:06   #2 (permalink)
Member: 78418
Thanks Meter: 2
try to clean it with alcohol or other,but release it before u do that,ok
Old 08-10-2005, 18:06   #3 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
Hi!
did u sucessfully repaired your problem? thn can u pls share it along with me?
WBR
ReyTech.
Old 09-15-2005, 12:42   #4 (permalink)
Member: 167773
Thanks Meter: 8
hi all
change the crystal ic near keypad connector,its ok now . Near the keypad connector 2 crystal ics 1st one is up and 2nd one is down. change the up crystal ic its for joystick
Old 09-15-2005, 15:40   #5 (permalink)
MADCIRA's Avatar
Member: 65352
Thanks Meter: 118
In my case,problem was flat of keyboard,change him!
Old 09-28-2005, 15:10   #6 (permalink)
Member: 157745
Thanks Meter: 4
hi all,change joystick
Old 09-28-2005, 15:11   #7 (permalink)
Member: 157745
Thanks Meter: 4
hi all,change key pad i.c
Old 09-28-2005, 15:12   #8 (permalink)
Member: 157745
Thanks Meter: 4
hi all,last is change CPU.................................GOOD LUCK
Old 09-28-2005, 16:43   #9 (permalink)
Member: 83476
Thanks Meter: 11
I have same problem (right joystick)and repair with changing key pad i.c before chenging ic try for dry solder or replace upper with down,good luck
Old 03-22-2006, 03:31   #10 (permalink)
Member: 248120
Nokia 6600 joystick not working
OK, I realise this thread is really old, but I am posting this reply, just in case someone does what I did when their Nokia 6600 joystick stopped working - searched everywhere for an answer.
BEFORE you replace the ICs, try CLEANING the joystick.
TURN OFF THE PHONE BEFORE DOING THIS.
All this involves is removing the faceplate and keypad, plus the rubber joystick cover thingy. The internal mechanism of the joystick is then able to be cleaned with either alcohol or some similar, non-residue, quick drying cleaning fluid. Try methylated spirits too, but just a little bit!
Couple drops into the base of the joystick, work the stick around, especially the direction it does not work (!), and hold the face/joystick down, so the grunge works it way out.
Do this a couple of times at least, and test each time for correct operation. If not working, then do it again.
If this fails to get it going, then you will have to go ahead with the ICs work.
Hope this procedure helps others, as it did for me.
The Following User Says Thank You to earthflute For This Useful Post:
Old 02-03-2009, 12:15   #11 (permalink)
Registered User
Member: 818659
Thanks Meter: 13
joystick left not move any button press ok inner keypad change same problem i have replace upper key pad problem clear ok
Nokia 6600 Backlight and Joystick problem Overdrive413 Nokia Hardware & Hardware Repair 2 11-15-2007 12:40
my 6600 joystick problem gm39772 Nokia Hardware & Hardware Repair 5 05-20-2007 18:18
nokia 6600 joystick problem? CHUMLEY Nokia Hardware & Hardware Repair 2 07-18-2006 14:20
6600 joystick move problem BackHam WD2 & APE (Symbian Phones) 1 11-17-2005 15:56
6600 Joystick seems stuck? YourPhone WD2 & APE (Symbian Phones) 0 08-11-2004 21:53
Page generated in 0.20501 seconds with 9 queries
