Old 09-04-2007, 13:10   #1 (permalink)
Member: 474407
Thanks Meter: 12
6600 not power on but charge ok
hi 6600 not power on but charge ok
Old 09-04-2007, 15:47   #2 (permalink)
navin71's Avatar
Member: 101891
Thanks Meter: 277
6600 on off ways
is the power switch ok check this track may help you
Old 09-04-2007, 16:38   #3 (permalink)
Member: 474407
Thanks Meter: 12
swith is ok track is ok but same pro?
Old 09-04-2007, 17:03   #4 (permalink)
Member: 52087
Thanks Meter: 10
same problem
6600 charge ok but not power on
Old 09-04-2007, 17:30   #5 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
check the track and most important is checking voltage
Old 09-04-2007, 22:12   #6 (permalink)
Member: 275451
Thanks Meter: 84
chk all diodes... one of them is not working..
Old 11-18-2007, 14:30   #7 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
6600 power switch + line broken any pictur solution plz.itz broken from resistor also.
ASHRAF
Old 11-18-2007, 18:46   #8 (permalink)
rk_grover77's Avatar
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
first check it with ufs or the flashing box u used is it on in normal mode or not then try checking track of power switch.
Old 06-16-2008, 14:10   #9 (permalink)
Member: 300261
Thanks Meter: 28
thanks man good work
Old 06-02-2009, 11:42   #10 (permalink)
Member: 1040091
.. boss try m i2...
Old 06-02-2009, 11:58   #11 (permalink)
MaFiaaa's Avatar
Member: 57930
Thanks Meter: 24
connect this jumper if not working its line under UEM cant repair
Old 06-02-2009, 15:57   #12 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 740
br this prient check
The Following User Says Thank You to biniesh_08 For This Useful Post:
Old 08-25-2009, 07:16   #13 (permalink)
Member: 1090831
Thanks Meter: 2
6600 problem .
charging but not switch on. when i connect the charger and switch the power on button it is on. how to repair
it
V3x no power on but charging ok gattus Motorola Hardware Repair 15 07-21-2007 08:25
6600 not power on but charging ottogsm Nokia Hardware & Hardware Repair 2 12-08-2006 11:26
6600 not power on but charge ok Ramiz Nokia Hardware & Hardware Repair 7 03-14-2006 19:43
A800 no power on but charging ok Cat10 Samsung Hardware Repair 13 03-06-2005 14:58
8210 don't power on.....but charge ok Pandemonio100 Nokia Hardware & Hardware Repair 4 05-15-2002 04:13
Page generated in 0.27090 seconds with 10 queries
