Old 08-05-2009, 05:17   #1 (permalink)
Member: 915413
Thanks Meter: 7
6600 only nokia help me
i flash phone ,erase flash and write flash but only nokia on display and no keypad light,i also reball ram ic but still only nokia on display local mode ok,what to do
Old 08-05-2009, 05:22   #2 (permalink)
Member: 511488
Thanks Meter: 8
hay change smps (boot ic) ur problem will solve 100% tested by me
Old 08-05-2009, 05:22   #3 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
try to hard format by hand ....hold * + 3 + call + power..
this way must help you...
Old 08-05-2009, 06:06   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.change this ic................
Old 08-05-2009, 09:13   #5 (permalink)
Swazi_Gsm's Avatar
Member: 317494
Sonork: 1000.1984
Thanks Meter: 187
first formet user area if failed then try with * 3 calling key on off switch still same then change boot ic
\100% solve
Old 08-05-2009, 09:21   #6 (permalink)
diabel02's Avatar
Member: 737175
Thanks Meter: 87
........same problem........
Old 08-05-2009, 09:37   #7 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
bro try like that:::
1/erase
2/full flash
3/writte pm
4/ui setting
5/formate
or try this:::::
Old 08-06-2009, 13:55   #8 (permalink)
Member: 915413
Thanks Meter: 7
i changed smps, changed black ic,also do ui setting and write pm,but still problem
1/erase
2/full flash
3/writte pm
4/ui setting
5/formate
or try this:::::
have u any other solution thanks
nokia 1110 ringer not working only plz help me ? ghaffar Nokia Hardware & Hardware Repair 9 10-14-2010 07:24
Nokia 6600 dead pls help me palav Nokia Hardware & Hardware Repair 2 12-16-2009 13:20
Application for Nokia 6600 - Can somebody Help me? Princeofislands WD2 & APE (Symbian Phones) 2 02-10-2004 21:48
Page generated in 0.18040 seconds with 9 queries
