Old 11-02-2005, 17:30   #1 (permalink)
Member: 53922
Thanks Meter: 11
6680 Insert SIM , Urgent help plz.
I had a bit problem when insert the JAF 6680 cable, (the cable made is impossible to fit into the phone, the SIM card socket blocked the way)
when I tried to put the cable in, and I forced it in, the SIM card socket came off. Now the phone doesn't detect SIM card any more.
There was one gold contact came off from the PCB as well, so I couldn't solder it back. Does anyone know how to fix it? Plz help.
BR.
Old 11-02-2005, 20:51   #2 (permalink)
Member: 8030
Thanks Meter: 3
It might be possible to solder a link from the relevant leg on the sim-card holder onto the track on the PCB where the gold contact used to be - then if that works glue the holder onto the pcb to stop it moving and breaking the repair.
If you're not much good at soldering then ask someone who is - otherwise it's a trip to the nearest nokia repair centre and a hefty bill (unless you can claim on any insurance you might have)
Old 11-03-2005, 11:05   #3 (permalink)
Member: 53922
Thanks Meter: 11
yes, I can solder a link but I don't know where is the track. Is anyone have any information? Thanks.
Old 06-17-2006, 11:12   #4 (permalink)
Member: 59489
Thanks Meter: 55
Hi,
Did you manage to find the track for the leg on the 6680? I have the same problem, please help.
Many thanks.
Old 06-18-2006, 15:00   #5 (permalink)
Member: 70916
Thanks Meter: 56
6681 offline/insert simcard solution
hai pls do not post same problem more times plz make search the forum for solution. search the forum for 6680 offline mode posted by meee 2 days ago
any see the attachment below,**** hot air on it or remove buffer ic give jumper like 3100
File Type: zip 6680 offline insert sim card solution copy.zip (189.8 KB, 875 views)
The Following User Says Thank You to jbbasha For This Useful Post:
w580i insert sim card help plz techno-gsm Sony Ericsson Hardware Repair 0 01-31-2009 19:11
kg 800 insert sim prob..help plz electro12 LG 2 05-07-2008 18:18
nokia 6680 insert sim ZEBUN Nokia Hardware & Hardware Repair 4 12-27-2007 12:23
6680 insert sim ahmad5175 Nokia Hardware & Hardware Repair 0 12-21-2007 07:40
6680 insert sim SURD ENT. Nokia Base Band 5 ( BB-5 ) 0 06-09-2007 06:32
Page generated in 0.15747 seconds with 10 queries
