09-24-2004, 00:22 | #1 (permalink) |
Junior Member Join Date: May 2004 Location: Midlands UK Age: 58
Member: 65235 Status: Offline Thanks Meter: 0 | 7250i dropped in water No responce from phone after it has been left to dry out, where do I start looking on the board, which name part would **** and what do I check for Many thanks for any Advice.... |
10-05-2004, 19:35 | #2 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44658 Status: Offline Thanks Meter: 0 | open phone, heat your HOME OVEN to 160-170C Place on baking tray, put in oven for about 4-5 MIN What you are doing is, reflowing the solder and reheating the IC's, and also drying out the water. Some say drying out water onto PCB will corrude the board, but also same time if you dont do it, it will corrude the board. Also check the board for ayny physical damage, ie/ capacitors removed, Do not use hair dryer to refow board, as the ****er and hear are not hot enough. thanks [email protected] |
3210 no signal after dropping in water | eureka8888 | Nokia Hardware & Hardware Repair | 4 | 11-11-2008 14:46 |
n70 drop in water i clean it but in box give this problem | جاسر مقدام | Nokia Base Band 5 ( BB-5 ) | 3 | 09-03-2006 10:18 |
3310 dropped in water now display leds are shorted out and on all the time.please hel | wildwhacker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-14-2001 16:01 |
3310 dropped in water ,still works but the display leds are on all the time | wildwhacker | Nokia Hardware & Hardware Repair | 1 | 08-13-2001 03:50 |
3310 Dropped in water | Blartiartfast | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-07-2001 11:14 |
