06-05-2008, 08:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: lahore
Member: 188574 Status: Offline Sonork: 100.1590742 Thanks Meter: 751 | 7610 showing error plz help me for this. Getting MCU ID MCU ID: 0x1081 FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\Rh-51\RH51_67PE706420.C2 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\Rh-51\RH51_67PE706420.C2 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\Rh-51\RH51PE706420.34 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,B.Mal.,B.Ind. (Apac-3) Chinese (Use MCU C2) Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\Rh-51\RH51_67PE706420.C2 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 37 Loader is ready... P-key nokia module version 01.02 MSID: 84268DDA6F0108F4D0E10897F3 MSID decoded: 3E4EBAF700937E44A8000000 FAID: 2F6BE570AA6421FCFADD8365 Operation took 0 minutes 23 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 029FFFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 2 minutes 52 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 26 seconds... Restarting MCU... Failed! Aborting! And if i press CHK button then showing following log : Getting MCU ID MCU ID: 0x1081 FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 i hope i given full detail. this phone was previous problem was white LCD due to that i tried to flash but now showing this problem. thanks in advance |
06-05-2008, 17:12 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Try to format your phone manually like *,3 green button & on off switch at a same time, Then only unlock the phone, if bluetooth is not open then repair bt by jaf or hwk. Thankz. Xtreme Mobile. BRB. |
7610 Showing Error. THIS SAME POST I POSTED ALREADY BUT NO RESPONSE RECIVED | NAVEED74 | Nokia Hardware & Hardware Repair | 4 | 07-07-2008 13:45 |
n70 show network full at call show error conection | gsm_khorshed | Nokia Hardware & Hardware Repair | 5 | 01-03-2008 10:46 |
7610 Show Nokia Only | ..::: Naveed :::.. | WD2 & APE (Symbian Phones) | 21 | 08-26-2007 08:19 |
7610 show picture | gpong | Nokia Hardware & Hardware Repair | 7 | 01-18-2007 13:13 |
7610 shows nokia after every 2-3 days | rroohhiitts | WD2 & APE (Symbian Phones) | 3 | 11-15-2006 02:53 |
