04-01-2003, 17:14 | #1 (permalink) |
Freak Poster Join Date: Feb 2001 Location: SPAIN
Member: 3377 Status: Offline Thanks Meter: 1 | AAArrrrrrgggg 8210 with 600 MA consumption and no way to find the problem Any idea friends? Thanks in advance and best regards |
04-01-2003, 19:34 | #4 (permalink) |
Member: 3377 Status: Offline Thanks Meter: 1 | thanks but donīt solve the problem, i mean you are referring to the both amplifiers near the filters on reverse of the pcb just behind the ringer, in anverse near the ringer only there is a big medium capacitor. |
04-01-2003, 20:10 | #5 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @DreamGsm I would suggest you unpack your multimeter, and next you check EVERY single capasitor around the CCONT. Had one 6210 today with same problem, but with 950 ma. Solution was that one (1) capasitor was shortcut and dragging the 1 leg of CCONT to ground which the phone absolutly did not like But now the phone is back to normal. Regards |
04-02-2003, 00:01 | #6 (permalink) |
Freak Poster Join Date: Feb 2001 Location: South Africa
Member: 3355 Status: Offline Thanks Meter: 1 | As far as I am aware (But I could be wrong ) If a phone draws a current of 600mA then something must get HOT in the phone! That should give a possible indication to what has malfunctioned. So just change that part! Just a thought - Use it, Dont Use it! Sho Cares |
04-02-2003, 11:10 | #7 (permalink) |
Member: 3377 Status: Offline Thanks Meter: 1 | not capacitors around the ccont, iīve allready changed all of them, about warmed component is good idea but no have time to warm the components at least no to feel the hot because phone switch off in seconds. well i will be back the phone to his owner, too much time with the phone.... thanks anyway mates |
Second and tested way to find Tx and Rx signal via pic! | Santehnik | Infinity-Box | 88 | 04-22-2016 20:30 |
..:: Easy And Safest way to Find Password (Spreadtrum) ::.. | jhepoy_org | VE-PRO BOX | 0 | 10-26-2009 05:47 |
Another way to find the pinout for Chinese phones! | Multi-box TEAM | Chinese Cocktail | 13 | 10-27-2008 01:33 |
the Right way to find the pin out | GalaxyMan | SpiderMan | 3 | 03-27-2008 21:11 |
