Chinese Cocktail All info about all chinese phones supported by Multi-box and Multi-box LITE is here. Please use this section for talks about china made phones |
11-14-2007, 14:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Hackers hell
Member: 327309 Status: Offline Sonork: 100.54567 Thanks Meter: 177 | Another way to find the pinout for Chinese phones! 1. At first, you need to find GND signal (3pin-00.2v) 2. The second step: you need to find Tx Rx signals. Choose the pinouts, that may probably suit. You have 12 pinouts: 1pin-0.00v - this pinout is wrong 2pin-2.78 - it may correspond to Tx Rx signals 3pin-00.2v - GND signal 4pin-2.75v - it may correspond to Tx Rx signals 5pin-1.09v - LOOKS LIKE Tx Rx signals, BUT IT IS NOT! 6pin-0.00v - this pinout is wrong 7pin-4.02v - this pinout is wrong 8pin-2.89v - it may correspond to Tx Rx signals 9pin-3.05v - this pinout is wrong 10pin-0.00v - this pinout is wrong 11pin-1.09v - it may correspond to Tx Rx signals 12pin-0.02v - YOU DON'T NEED these fake signals with high and low voltage 3. In order to find Tx you need to put multimeter to test, diod ( "+" and "-" = beep ). When the phone is POWERED ON, Tx with GND make a sound beep. When it is TURNED OFF, it shows 600-700 ohm. It is suggested to do all the job using wire connection. After following the above mentioned steps you'll find, that 2pin is Tx and 8pin is Rx. Tx has to be 1.7v or 2.7v and Rx - 1.8v or 2.8v. These characteristics may change depending on the processor parameters. But Tx and Rx is not the same. Tx can be 2.78v, 2.75v, 2.7v. |
The Following 9 Users Say Thank You to Multi-box TEAM For This Useful Post: |
02-25-2008, 08:12 | #11 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | goood work br for any dead phone of chines just hit fire with brower range of 350c . your phone will be ok. |
The Following User Says Thank You to GSM SKILS For This Useful Post: |
How to find a pinout for Chinese phone? EASY! | Multi-box TEAM | Chinese Cocktail | 31 | 05-05-2012 20:54 |
Flash site to download the update for Chinese phones continuously | hamada-almasry | GSM Mobile Links | 5 | 04-08-2010 11:37 |
Spiderman BOX cann't find the pinout for MTK6235 Chinese Blackberry 9630 and 8900 | Luigirox | Chinese Models & Cloned Phones | 2 | 03-06-2010 09:08 |
where to find eeprom file for chinese phones ? | gsmdok | Infinity-Box | 1 | 08-17-2008 11:20 |
how to find the pinout of first and second cpu of dual cpu phones | maximas007 | Infinity-Box | 3 | 03-20-2008 05:38 |
