10-21-2002, 19:45 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Location: North Pole
Member: 12869 Status: Offline Thanks Meter: 3 | Big problem After Changing PA |
10-23-2002, 23:16 | #7 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | Remove PA and check if all contact was good conected to PCB...no one shold be gold, but silver after good soldering...If is all OK, maybe ist it COBBA or HAGGAR (bad conection to PCB, just reflow it) or replace FDK. |
10-24-2002, 11:26 | #8 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | I hot you did put together ur tool, if not u'll never get goog result chnging ur PA or ant sw . other possibility is to remove the tip of ur magnum hot air to improve ur air flow control. Goodluck ____________________________ All I know is I know nothing |
11-21-2002, 19:25 | #9 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | 3310 Hi Black-Axe what antenna switch are you using ? the ones i get in cape town are s**t after replacing them the phone has poor signal let me know you got my number Later D. |
11-22-2002, 02:04 | #10 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Egypt Age: 45
Member: 14194 Status: Offline Thanks Meter: 4 | hi Black-Axe first remove the new pa you replaced then power on the phone without pa and check the signal is it low or good? if the signal is good then your pa is not good if the signal also low then you must check your antenna switch and antenna if good then rehot or reball ccont it happend with me more than one please send result you can try this solution for antenna switch on this page http://groups.yahoo.com/group/wes_na...okia/Hardware/ Wesam |
6310 start up problem after change pa | gsm_style | Nokia Hardware & Hardware Repair | 3 | 11-09-2004 21:08 |
T28 problem after change PA. | chris_ua | Sony Ericsson Hardware Repair | 2 | 10-05-2002 07:37 |
T28s random signal after changing PA- help pls | chrisro | Sony Ericsson Hardware Repair | 7 | 11-19-2001 18:45 |
T28s random signal after changing PA | chrisro | Old Ericsson Phones & Sony Phones | 3 | 11-15-2001 19:51 |
T28 No access after change PA | fm-gsm | Sony Ericsson Hardware Repair | 4 | 11-03-2001 18:32 |
