05-02-2005, 07:14 | #1 (permalink) |
Junior Member Join Date: Apr 2005 Location: Philippines Age: 43
Member: 137075 Status: Offline Thanks Meter: 6 | calculating uem can somebody help me, if it is possible to calculate only the uem? bcoz i calculate the flash already but when im writing the rpl it is not puting the imei,need help |
05-02-2005, 14:28 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | rpl file can be write on UEM for 1 time only, if you make some mistake when writing rpl or something like that, you need to change UEM again and write new rpl |
05-02-2005, 14:39 | #3 (permalink) |
Freak Poster Join Date: Nov 2004 Location: everywhere Age: 46
Member: 94023 Status: Offline Thanks Meter: 23 | Hello 1. Change UEM-chip from phone 2. ERASE all flash(optional, but i would reconomend this) 3. flash phone (only if have used step2) 4. read UEM/make ASk file and enter desired IMEI number (of course a number that is not barred) 5. sent this ask file for calculat 6. write .rpl that you will get from me to phone ... and Voila, phone have new IMEI number you should do same procedure with every barred phone. (of course you can use only one generated .rpl and write to all phones, but if someday t his number will be barred then all phones that have same number will be blocked as well) bestregards, |
After removal of glued UEM and glued uem removal video guide | Raheeeeb | Nokia Repair Guide and FAQ | 254 | 06-19-2019 01:40 |
Invalid uem checksum, UEM might be damaged ! | naveed ali | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-11-2010 16:36 |
DCTxBB5 2.0.8.5 HWK -> Read UEM OK! Write UEM Failed! | [Shadab_M] | HWK | 3 | 06-09-2009 07:38 |
Need calculated rpl for 8800 RM-13 empty UEM | starpho | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 11-13-2008 12:24 |
UEM 4376371 IN STOCK FOR UEMe 4376371 For Nokia 7610, 3220, 3230 ETC | afacandenis | Main Sales Section | 0 | 08-04-2006 15:27 |
