Old 02-27-2004, 23:01   #1 (permalink)
Member: 45373
Thanks Meter: 3
to change bga chips
exists an cheaper tool that concurs to align the new one perfectly bga when it must replace it? I have big problem in order to put in position by hand also ccont and the hagar of the 8200.
tnx
Old 02-28-2004, 10:53   #2 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
Hi
You don't need to position your bga exactly on the board. When you solder the bga it automatically positions him self by a thing that i don't know how to translate in English
check this http://forum.gsmhosting.com/vbb/showthread.php?t=123628 it will help you
Old 02-28-2004, 16:49   #3 (permalink)
Member: 44658
use the red lines on the pcb board, to help to line it up
Old 02-28-2004, 18:19   #4 (permalink)
Member: 39601
Thanks Meter: 13
Yes as " Engeneer " says use the red lines on the PCB to guide you , befor U have to clean the PCB pads by the wick sheild to get the soldiering pads flat ( extra soldier forms dome shape , that makes balls on BGA glides over them ).
Then some drops of flux , instaull it within the marks lines (useing one eye and adjust it from above).
Then hot gun and goodluck .
Old 02-28-2004, 21:43   #5 (permalink)
Member: 45373
Thanks Meter: 3
Tanx very mutch guys,I understand all,I bougth a kit from mobilerepair.de.
Tanx again
Old 02-29-2004, 02:36   #6 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
i will give you only 1 advice :
don't use the paste that included on bga repair kit's (for reballing)
after 1 year searching finaly i found the real working paste.
Old 02-29-2004, 07:37   #7 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
my friend platijet which is????
which solder paste?
Old 02-29-2004, 19:14   #8 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@All
The solder paste Platijet is talking about is the following called HIGH NPAI SOLDER PASTE. I bought this at the time I was in Bangkok. But I have not been able to find it anywhere on the internet. For me this is the best paste to use. I made a demonstration of the manual reball process a couple a days back with a MAD2 and my stencil kit which I'm used to now. And with this solder paste I get perfect results nearly every time!
More info on this solder paste :
Product number : ON-8088-410F-63-9.6
Maybe if somebody is working/living in Bangkok, you can get this on 4'th floor of Mae Bong Krong shopping center, you guys wont believe what you can find for mobiles there
Regards
Old 02-29-2004, 19:22   #9 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
regards....
Old 02-29-2004, 20:21   #10 (permalink)
Member: 31028
Thanks Meter: 56
but the past that comes with stencil works too right???
Old 02-29-2004, 20:24   #11 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
no doesn't work
2651 to 2650... Needed to change flash chip? -luigi- Nokia Hardware & Hardware Repair 3 07-19-2007 18:52
How to change flash chip to unlock k800? joan6668 Cruiser Suite 1 12-15-2006 05:07
helpfull way to change sealed chips ? topdinosaurs Nokia Hardware & Hardware Repair 16 10-14-2005 22:39
can i use this to change uem chips jabran200 Hardware Equipments for GSM 3 10-22-2004 13:39
Hot air station to change bga? sureshkumar13 Hardware Repair by brands 2 02-19-2002 04:44
Page generated in 0.18782 seconds with 9 queries
