04-07-2005, 18:19 | #4 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | 7610b to 7610 Quote:
yes you can do that, i converted one phone today, flash with 7610, write PM (7610) unlock full factory, format user area. then change 3 filters aroung rf IC. that is all you need, with my best regards. Mansi | |
04-08-2005, 06:14 | #5 (permalink) | |
Freak Poster Join Date: Sep 2004 Location: PH,MANGAFF KUWAIT Age: 41
Member: 81289 Status: Offline Thanks Meter: 236 | Quote:
04-10-2005, 14:44 | #6 (permalink) | |
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Quote:
yes 1000% sure softwarea: 1-flash with 7610 2-write PM file (7610) to the phone 3-unlock 4-full factory defaults 5-format user area hardware: 1-open phone 2-open metal cover the one in the top of the phone (RF IC is under it) 3- change the filters around the I.C (the littile black ones) you can replace from a nokia 6100 or 6310i. you are ready to use your phone on 900-1800Mhz networks best regards Mansi | |
05-26-2005, 12:27 | #7 (permalink) | |
Junior Member Join Date: Feb 2005 Age: 39
Member: 117237 Status: Offline Thanks Meter: 0 | Quote:
05-29-2005, 18:54 | #9 (permalink) | |
Junior Member Join Date: May 2005 Age: 42
Member: 149137 Status: Offline Thanks Meter: 0 | Quote:
05-29-2005, 19:12 | #10 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Alex EG Age: 42
Member: 120869 Status: Offline Thanks Meter: 28 | Quote:
B.r | |
05-30-2005, 13:54 | #11 (permalink) | |
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | replay Quote:
05-30-2005, 17:51 | #12 (permalink) | |
Thank you always. | |
06-22-2005, 19:30 | #15 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 51
Member: 59979 Status: Offline Thanks Meter: 1 | "try changing SIM card it might be "not valid", if still the same check SIM card connector pins, if there was a loose in connection the phone always make "sim card registeration failed" and some other stupid errors " You try _ write Pm - Format use erase - init simlocks OK |
how to convert 6670 to 7610? | hooi76 | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 04-05-2006 17:40 |
