02-05-2009, 21:01 | #1 (permalink) |
Major Poster Join Date: May 2005 Age: 41
Member: 143538 Status: Offline Thanks Meter: 0 | E51 not work. Please HELP! Phone does not start up. when pressing the power key. When pressing the power key notification light and display backlight wake up. Vibra makes on jog. Phone will take 230 - 250 mA current, but nothing else happens. After 30 seconds phone will power off. Solution not work!!! Procedure: 1) Flash E51_blank_504KB_pmm_10.fpsx file to phone with firmware update: Firmware Update-> Options -> select E51_blank_504KB_pmm_10.fpsx into Image field and empty other fields 2) Flash the whole SW package to phone with firmware update 3) Run factory settings Phone should work now. Phone memory is empty and you can't save any old data from phone memory. Memory card and SIM card should work as earlier. I flash my phone V 100 and 200 and 300, not work. UFS log press check: 1ST BOOT : C0,07 [Rm-244] [2.0.8.0] RAPx ID : 000000010000022600010006400C192101021103 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 14600102796B0052B49E2E689A9025BE9CAFAEED RAPx MODE : 00 RAPx HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE RAPx ROID : A8C1D6713E691FF8 CMT 1ST Boot OK CMT 2ND Bt: RAPIDOv11_2nd.fg, Ver: 1.30.0 CMT FLID0 : 00EC0040-00600022, Sam OneNAND-2G CMT FLCNT : 00030000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAPIDOv11_algo.fg, Ver: 1.35.0 CMT KSIG0 : 35AC54F8E31BE1357AB78D73834F020906331653 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent Rebooting Mobile UFS log press info: MCU SW : V 200.71.814 09-04-08 RM-244 (c) Nokia PPM SW : 200.34.36 Prd.Code: 0555751 Bpr.Code: 0545341 Prod.Sn : SAP364075 HW Vers : 0801 EM VILMA: 15 EM BETTY: 22 RFIC Ver: 17141715 DSP Vers: SI07w15PB_08w10 WLAN Id : 6FD30DDF1F IMEI : 354193-02-777098-6 SL Serv : SIMLOCK SERVER SL Conf : 244-07-00000000000 SL Stat : 0000000000000000 SL Count: 00 00 Provider: Nokia Test;Finland Check, flash, info, local mode, test mode, self test - work!!! Normal mode - Init Normal Mode Failed, Fatal Error Please help... |
03-23-2009, 11:06 | #3 (permalink) |
Junior Member Join Date: Dec 2006 Location: india Age: 37
Member: 404729 Status: Offline Thanks Meter: 0 | pls let me yhe the following regarding E-51 1.set is showing charging but there is no reponse means ON. 2.ON/Switch ic location . pls provide as soon as possible. thanks |
Nokia 6220 Data Cable not working. Please help... | Muzzy | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 07-22-2004 20:38 |
3300 KEYS"0" "4" not working please help me | mohammed | Nokia Hardware & Hardware Repair | 0 | 05-10-2004 22:21 |
EMMI-2D Not work,,,PLEASE HELP! | VsH-GsM | Motorola Old Legacy (EMMI) | 2 | 06-03-2003 23:46 |
C55 - JavaActivator not worked - please help me | MrK | E-Gold Based Phones | 2 | 04-19-2003 23:32 |
