E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
04-18-2003, 22:11 | #1 (permalink) |
Major Poster Join Date: Mar 2003 Location: Poland Age: 45
Member: 25037 Status: Offline Thanks Meter: 0 | C55 - JavaActivator not worked - please help me I have a problem. Soft v18. I tried to unlock memory access flash with the help of Java Activator by SkyLord, but it would miscarried unfortunately I find description, in which they tell to connect to suitable points of contact the tension 4,5V (http://digilander.libero.it/m_50/). I try, but it does not it want also to get down to work so I it have not memory access still flash How to unlock flash memory? I for every advice from mountain thank. I apologize for weak English. |
04-19-2003, 06:26 | #2 (permalink) |
Junior Member Join Date: Oct 2002
Member: 16759 Status: Offline Thanks Meter: 0 | C55 old Cable upgrade and Java Unlock Post #1 of 1 I have read many discussion about the cable modification and java unlock yesterday in pass topics. I am not sure is all be resolve by those who discuss, I read them all and finally figure out every thing (I think). So I am writing this to clearify to those still unclear on how to do it. (For expert, please correct if I am wrong) ------------------------------------------------------- You can upgrade the old (x45) non original cable to new C55/S55 cable. Why? Because the original cable designed such a way the RS232 IC located in the DB9 connector is power from the cellphone, while non original cable uses power by the COMM port. OK, open up the old cable, swap these pins: Old (x45) New (x55) pin 1 (gnd) ---> pin 2 (gnd) pin 5 (tx) ---> pin 3 (tx) pin 6 (rx) ---> pin 4 (rx) many are discuss about the pin 1 (auto init), I did not connect to a +4/5 V but still works fine, either in unlocking or data transfer. Oh Year, you have take out the small metal plate from the old cable and cut with a knife to trim the old connector to fit in the x55. Ok, some had said that after unlock, claim ok by the software but still not working. I found that Skylord new unlock software with the disable aircraft check is not working for C55 and M50. Use the old one without the disable aircraft check, it shall unlock. Remember to power down your phone, start and run the software and them press the red button on the phone briefly. And unlocked!! (if you need the software i can email to you guys, drop a mail at [email protected]) One more thing, to test is the cable is OK after modification, connect the cable to phone and run HyperTerm in windows, and try sending "AT" command see is the phone reply with "OK", if not, the cable is still not working yet. Bye! |
6030 menu key not working, please help me | gsm_surya | Nokia Hardware & Hardware Repair | 5 | 02-14-2008 18:42 |
All LG M1 module Unlock and flash not work.......Please help me! | bimson22vn | FuriousGold | 12 | 10-25-2007 22:24 |
HWK not working please help me | pedro7208 | HWK | 5 | 07-31-2005 20:05 |
3300 KEYS"0" "4" not working please help me | mohammed | Nokia Hardware & Hardware Repair | 0 | 05-10-2004 22:21 |
