Old 02-25-2009, 15:11   #61 (permalink)
Member: 866431
Sonork: 30505724
Thanks Meter: 4
Originally Posted by tcs1337 View Post
nk3650 was dead.flase and formet set on but now prob is here when call any number set restart and off what is the prob please post here as soon as
try to flash it again with a good flash file. if the problem still remain replace the flash ic.
The Following User Says Thank You to romelpalaran For This Useful Post:
Old 02-26-2009, 05:57   #62 (permalink)
Member: 403881
Thanks Meter: 80
Originally Posted by digitized View Post
remove power ic & then check it....
Once more i am repeat here the component are listed those i have REMOVED.
1.POWER IC
2.PA
3.CHARGING IC
4.RINGER IC
5.COIL (light)
but still the set shot.
The Following User Says Thank You to sarojrkl For This Useful Post:
Old 02-26-2009, 07:46   #63 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
1.POWER IC
2.PA
3.CHARGING IC
4.RINGER IC
5.COIL (light)
as u say that u remove all these comp for ur knwlodge i want to say that there is no charging ic in nokia 1650,1208,1200 ur charging ic is in power ic ...
regarding ur problem ...
if ur bord is water damage then u have to check the area which damage by water most and those capistor which are in brown colour and got +b from batery & also check ur vibrator because vibrator also got +b...& u also check flash light because flash light also got +b....
post result ....
The Following 3 Users Say Thank You to digitized For This Useful Post:
Old 02-27-2009, 08:34   #64 (permalink)
Member: 956176
Sonork: shahzadhuma
Thanks Meter: 5
please tell me nokia 1200 network problime
The Following 2 Users Say Thank You to shahzad6r For This Useful Post:
Old 02-27-2009, 14:22   #65 (permalink)
Member: 909700
good tutorial for newbie like me
Old 02-27-2009, 14:27   #66 (permalink)
.::PATEL TELECOM::.'s Avatar
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
how chack in nokia 6500 shorting plese help
Old 02-28-2009, 16:07   #67 (permalink)
Member: 914945
Sonork: babo
Thanks Meter: 2
1600 light prombal ok give me soulion
Old 03-02-2009, 08:44   #68 (permalink)
Member: 403881
Thanks Meter: 80
Please help me to remove the shot shown in picture
Its N70 white screen and hang the three capacitors(C7602,C5000 and C4206) marked in the picture are showing shot. I have removed Both the small ics SMPS and APE REGULATOR but still showing shot so that i can not apply jumer without removing the shot. So please help me to remove the shot shown in picture.
It will be kind enough if u could treat it as urgent.
Regards,
The Following 11 Users Say Thank You to sarojrkl For This Useful Post:
Old 03-02-2009, 15:29   #69 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
Regards,
any solution for this problem
i have same problem plese help
Old 03-03-2009, 14:23   #70 (permalink)
Member: 873585
Thanks Meter: 3
6630 offline mode plz. help me
Old 03-03-2009, 14:51   #71 (permalink)
Member: 873585
Thanks Meter: 3
5200 momery card don,t show plz. help me
The Following User Says Thank You to Bikas Das For This Useful Post:
Old 03-03-2009, 15:05   #72 (permalink)
Member: 873585
Thanks Meter: 3
Old 03-12-2009, 11:50   #73 (permalink)
Member: 910018
Thanks Meter: 7
hai this is manzoor please will u do me one favor please i am using nokia 6600 model actually what happen camera is not working when i take a snap means this message is coming temporary over load when i open gallery means i takes 5 mintues or more time to open i am using memory card only 64mb i done format by pressing *3 call button and on/off switch format is completed and i done format mmc card also but 1 or 2 snaps again it get same problem so it better to do flash or any another problem is that and recently i done format after 3 days now it is working when i open blue tooth means again it is going and all are opening but songs in the mmc card is not playing when i open realplay it shows no data but i open file manager in that its showing the songs but unable to play why please please solve my problem as soon as possible bcoz its my fever ate pice and 1 more thing u r frm and is their espert in hyderabad to solve my prob did u have any i dea please solve my prob thanking you
Old 03-12-2009, 11:55   #74 (permalink)
Member: 910018
Thanks Meter: 7
solve my problem
The Following 3 Users Say Thank You to manzoore elahi For This Useful Post:
Old 03-12-2009, 11:56   #75 (permalink)
Member: 910018
Thanks Meter: 7
The Following User Says Thank You to manzoore elahi For This Useful Post:
Page generated in 0.37963 seconds with 11 queries
