08-01-2013, 11:36 | #1 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1986751 Status: Offline Thanks Meter: 0 | Flashing Nokia 301 RM-840 ------------------------------------------------------------------- The flashing failed. Do you want to retry the flashing? HRESULT 0x8401f141 (-2080247487) Flash: Boot rom was not detected after phone boot up. Unable to start flashing. ------------------------------------------------------------------- How do I solve this? I am on a windows 7 64 bit machine. |
08-01-2013, 21:40 | #6 (permalink) |
Member: 1986751 Status: Offline Thanks Meter: 0 | I get this output from Phoenix: ------------------------------------------------------------------------------ Flashing started Creating product data items list Product data items list created Backing up data items Backing up data items Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, skipping backup DataItem "ISSVariantActivator" version "1.0" set to defaults, skipping backup Starting backup/restore sub-procedure: mode change post delay mode change post delay mode change post delay Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: File2Files, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Backup complete Flashing phone Initializing Download files list initiated Verifying communication to device... Waiting for USB device... ------------------------------------------------------------------------------ While Phoenix is waiting for USB device, the phone is in test mode, and the conncetion to phoenix is lost. Then after a while the error is popping up |
08-01-2013, 21:41 | #7 (permalink) |
Member: 1986751 Status: Offline Thanks Meter: 0 | I follow this guide : Nokia language change with Phoenix Service Software - CPKB - Cell Phone Knowledge Base |
08-01-2013, 21:54 | #9 (permalink) |
Member: 1986751 Status: Offline Thanks Meter: 0 | I have spend the last day searching for the newest Phoenix software, but this was the newest I could find. If you know about any newer version please let me know where to find it |
08-02-2013, 11:56 | #11 (permalink) |
Member: 1986751 Status: Offline Thanks Meter: 0 | It seems like Windows is trying to install a Nokia USB ROM driver ? Could this be the problem that Phoenix can connect to the phone while it is in test mode? I have of course installed the latest version of the Nokia Connectivity Cable Driver, but it seems like it is not enough? |
08-28-2013, 08:06 | #13 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2012610 Status: Offline Thanks Meter: 0 | solution i just registered to help so i cant post link google Nokia 301 flashing problem click first link besides ads its in this forum too windows device manager something ?mark device called nokia usb rom or something install driver manually good luck |
05-16-2014, 13:16 | #14 (permalink) |
Junior Member Join Date: May 2014
Member: 2186348 Status: Offline Thanks Meter: 1 | Same problem here I have exactly the same problem, on win xp, win7 and win8. More details: on Win XP the problem is most clear: halfway the procedure the 'Found new hardware' wizard pops up, asking for driver for 'NOKIA USB ROM'. On win7 I don't get the option of installing a driver manually; only the error: device not installed. The device is only briefly visible when I try to flash; it appears in the device list under 'other devices' for 2s, then disappears. With win8, no error messages, but afterwards there is something visible in the devicemanager: when 'show hidden devices' is checked, there is a section 'other devices' with NOKIA USB ROM greyed out and with the 'driver not installed' symbol. I use the latest version of Phoenix. Tried everything suggested on this forum and elsewhere: installed and de-installed the latest data cable software from Nokia, even the PC-Suite (which doesn't support this phone.) The problem is driving me crazy, because others on this forum succeeded without this problem; someone I know got it to work on windows8, but he cannot say why it works for him but not for me:-( Could it be because I have win8/64 instead of win8/32? (I read somewhere a warning about that) ewr: manually installing this driver seems a good suggestion; might work on XP and maybe win8. But I can't find the driver-software (just lots of those ****ty driver-downloaders promising the goods but not delivering them, only advertisements). Mabel |
