Old 12-31-2008, 12:58   #1 (permalink)
Member: 871978
Sonork: rana
Thanks Meter: 5
Exclamation help me for nokia 6070
nokia 6070 when connectd to power supply draws 100mA current,and when power on button is pressed it drwas 500mA current for fow seconds,and then again stays at 100 mA.what is solution ,plz urgently help me,...........
Old 12-31-2008, 13:05   #2 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
what?????????????????..............
The Following User Says Thank You to RATHNAMOBILESS For This Useful Post:
Old 01-03-2009, 00:19   #3 (permalink)
Member: 871978
Sonork: rana
Thanks Meter: 5
connected to xtrenal power supply not with charger,it shows the curent used by 6070 is 100 mA(0.1A)without pressing power on key,as p.key is pressd it starts cunsuming 500ma.curennt for just few seconds and then again 100 ma>.......it is not powering on.....
Old 01-23-2009, 00:01   #4 (permalink)
Member: 905846
Thanks Meter: 26
I presume that your 6070 been in the water or you made a little "snafoo" while soldering, am I right? :-)
Any how, I recommend you to reheat the upp with alot of flax.
Upp or the part that heats up (0.5A is alot of current ussually it's make heat in dameged areas of the pcb)
If this doesnt help, here's a technic that I found out when headset peaks 400mA and above and you want to pin point the area that heats up
1)Take a litlle of chewing gum, chew it
2)Turn on the pcb with power supply few times, and feel with your hand what part of it heats up.
3)Stick the chewed gum on the hot area of the pcb
4)turn the pcb few more times untill it heats up again.
5)Quickly remove the chewing gum from the pcb
then you will see that the gum stuck to the main sourse of the heat area. you can remove the pices of the stucked gum with flux cleaner sprey or Allcohol.
this technic can even pin point what part of the Bga commponent heats up.
6)Resolder that area with alot of flax, or even change it if you have the tools and the expiriense.
Good Luck
help me for nokia 3125 rh61 tianma Nokia CDMA 17 06-28-2009 11:22
help me unkock nokia 6070 please! mobilegs4less Phone Unlocking Codes & Maps 3 02-17-2008 19:08
help me unkock nokia 6070 please! mobilegs4less Phone Unlocking Codes & Maps 2 02-05-2008 12:06
help me for nokia 3100 M jamshed iqbal Nokia Hardware & Hardware Repair 7 06-23-2007 22:24
Page generated in 0.13544 seconds with 9 queries
