Old 11-14-2008, 23:04   #1 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
how to correctly change nokia 1208 charging jack
can any one give me a right procedure to change a nokia 1208 charging jack
as it is soldered and i want before starting to know what is the right way to change it to avoid any harm
Old 11-15-2008, 07:11   #2 (permalink)
Member: 900323
Thanks Meter: 3
simply do it carefully to avoid light damage
Old 11-15-2008, 07:50   #3 (permalink)
Member: 774262
Thanks Meter: 42
remov with heater and replace with soldering tool
Old 11-15-2008, 07:55   #4 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
remove charging pin using hot air
reheat the back board infront of charging pin
replace with same procedure...
it is safe procedure bro...
Old 11-15-2008, 07:57   #5 (permalink)
Crazy Poster
Member: 639200
Thanks Meter: 10
use staple wire to change the pin if broken.....
Old 11-15-2008, 08:27   #6 (permalink)
Member: 266277
Thanks Meter: 8
the first time i also think the same problem, but now its a simple 5 minutes job for me.
first put flux to the pins, then with hotair, heat the headset part first, slowly lift and start to heat the middle part. (i found it easier if i heat the headset part first)
Old 11-15-2008, 09:22   #7 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
1208 charging base
Brother the best is remove with heater and new connect pcb with soldering gun
Old 11-15-2008, 10:30   #8 (permalink)
bgreat's Avatar
Member: 727235
Thanks Meter: 1,211
brother its so simple to remove firstly remove with hot gun then use iron to joint it
Old 11-15-2008, 12:54   #9 (permalink)
Member: 694394
Thanks Meter: 2
i use to need as replacement of the pin first you must take out the pin stopper you can see at the top of chaging pin so you can easily put the needle
this how to locate the pin stopper you will need a cutter look for small tin metal
sorry i dont have camera to show where the exact place of this stopper but when you try this solution you can tell now how easy and safe with out using hot air
Old 02-04-2009, 18:32   #10 (permalink)
Member: 901738
Thanks Meter: 8
Nokia 1208 Charging Way
Plz some One direct me the way of charging 1208
I have 1208 Nokia Phone Fall Damage ..
every thing OK but Charging fault occur.
Old 03-26-2010, 16:50   #11 (permalink)
Member: 676046
Video
CAN U PLEASE GIVE ME THE VIDEO OF REPLACING CHARGING JACK OF 1208 etc
Old 03-26-2010, 18:40   #12 (permalink)
noagsm's Avatar
Member: 606593
Thanks Meter: 68
YouTube - NOKIA 2630 charging connector repair
The Following User Says Thank You to noagsm For This Useful Post:
Old 03-27-2010, 06:56   #13 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 354
just change pin no need to change whole charging socket it is very simple i often use capacitor pin as a charging pin
Old 04-21-2010, 17:57   #14 (permalink)
Crazy Poster
Member: 670128
Thanks Meter: 6
another method is.. u can use l.e.d. legs for this easily..im using this method for broken charging socket pin..it takes about one and half minute only..
nokia 1208 charging problem saqi160 Nokia Hardware & Hardware Repair 12 04-17-2013 07:00
How to correct nokia 5800d imei 12345610654321? Moha1974 Cyclonebox 7 12-18-2010 21:33
nokia 1208 lcd jack ways wanted adnan_gsm Nokia Hardware & Hardware Repair 3 12-17-2009 09:44
how to imei change Nokia 5000d Qaisar Mahmood Universalbox 1 12-07-2009 10:29
explain full procedure on how to unlock a nokia 1208 chit chat Nokia Digital Core Technology 4 ( DCT-4 ) 5 08-09-2008 18:18
Page generated in 0.28002 seconds with 9 queries
