03-21-2004, 17:57 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: MADAGASCAR Age: 42
Member: 28378 Status: Offline Thanks Meter: 3 | Low batt with Nokia 3310 |
03-21-2004, 23:50 | #4 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Minsk Russia
Member: 5569 Status: Offline Thanks Meter: 10 | @gjurobrod yes first step right good but still pb. try check curent or use multimeter R*1 check battery tip between tip+ and tip- with good phone and your phone [may be apare part leak; condenser] regards Own |
04-21-2004, 07:26 | #9 (permalink) |
Junior Member Join Date: Apr 2004 Age: 41
Member: 63119 Status: Offline Thanks Meter: 2 | i also have same probs in one of 3310 i had chaned pa, CCONT,ANTENA SWITCH, BATTERY CONNECTOR, BATTERY, AND ALSO EVEN I HAD FLASHING WITH ROLIS FLASHER BUT SAME PROBS IS ANYBODY THERE WHO CAN TELL THE EXACT SOL I WILL BE VERY MUCH THANKFUL OF URS BUDDY......! THX IN ADVANCE |
04-23-2004, 13:21 | #11 (permalink) |
No Life Poster Join Date: Dec 2003 Location: BiH Age: 49
Member: 46341 Status: Offline Thanks Meter: 15 | I read many people in this forum hawe big problems whit 3310 batery low and power of when during coll. From my expirience I newer slove this problem yust by changing pa, i tread chnging pa many times but same thing. I wonder in 3310 change oll bgas 100% ok bga, but same thing, olso clean and chek batery conector, put new org batery no help stil power of when coll. But helps me much when i put batery from 3410 because that batery is a beat stronger, but in some cases evan that not help me. I read old post that this problem could be sloved by rx tx calibration, to calibrate rx tx to consuming lees power when coll, but did not tread this yet. In some pcbs i notice when heat around hagar phone works 2 or 5 minutes ok bu when get cold batery low, that means cold be some chaps around hagar. |
04-24-2004, 13:34 | #12 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Turkey Age: 43
Member: 2088 Status: Offline Sonork: 100.1630154 Thanks Meter: 57 | measure the current from bettary connectors while calling if it is more then 400mA's it is because of PA if less because of battery that's it. |
05-29-2004, 19:23 | #13 (permalink) | |
No Life Poster Join Date: Mar 2004 Age: 67
Member: 58052 Status: Offline Thanks Meter: 21 | Quote:
05-30-2004, 07:08 | #14 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 71
Member: 58466 Status: Offline Thanks Meter: 19 | I 2 had the same problem with 3310.But by changing pa I could'nt solve the problem I reballed ccont,did a fullflashing& the set is ok.Mostly this problem occur due to substandard chinese batteries,leakage in PA,change over switch,corroded battery contact.Check all these things.Best of luck. |
Strange problem with Nokia 3310 | Chawek | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 02-27-2002 22:47 |
newbie : First play with nokia 3310 | haf | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-11-2002 22:58 |
Strange Contact Service problem with Nokia 3310! Take a look... | laxxe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 06-14-2001 20:16 |
Strange problem with nokia 3310 v4.19 | terys | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-26-2001 19:42 |
problem with nokia 3310 v418 | rebel115 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-07-2001 00:33 |
