09-28-2009, 20:16 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | check charging if you listen charging beep,then ... 1-check power switch. 2-change right side lcd ic. 3-rehot retu/change retu. if no effect with charger then...... 1-rehot/reball retu. 2-rehot ram. 3-rehot combo flash. 4-rehot/change tahvo. 5-rehot RF ic. 6-rehot version flash rom. 7-rehot cpu. try it and post reply regards. |
n70 flshing problem phone is dead | mobiletuch | Nokia Hardware & Hardware Repair | 7 | 12-05-2009 11:24 |
N70 display ic ok bt phone still can'nt display | luyanda | Nokia Hardware & Hardware Repair | 6 | 10-26-2009 11:23 |
N72 Camera Flash On But Set Is Dead After Pressing On/off Switch | gsmsoftware77 | Nokia Base Band 5 ( BB-5 ) | 3 | 07-09-2008 18:41 |
N3310, vibra & LEDs are on when connect battery, but phone is dead | MaRiN | Nokia Hardware & Hardware Repair | 8 | 02-20-2003 02:32 |
