02-18-2003, 00:47 | #1 (permalink) |
Freak Poster Join Date: Nov 2000 Location: Croatia Age: 47
Member: 2466 Status: Offline Thanks Meter: 10 | N3310, vibra & LEDs are on when connect battery, but phone is dead When I disconnect, and connect battery, vibra, and leds are on, and always the same... I changed N400, and rehot pcb, but nothing I try to flash it, but phone doesn't respond to flasher... Does anybady know where can be a problem? |
02-20-2003, 01:19 | #8 (permalink) |
Member: 2466 Status: Offline Thanks Meter: 10 | I changed ccont, but nothing This phone is not water damage, but I think that this phone droped in some oil or something like oil. Before rehoting phone was dead, and sometimes it succes to power on, but only for max 30 seconds, and then powers off by itself. After rehoting all pcb (except cpu, ram and flash) vibra and lights are always on until I press power on button. |
02-20-2003, 02:32 | #9 (permalink) |
Freak Poster Join Date: May 2002 Location: egypt Age: 46
Member: 11466 Status: Offline Thanks Meter: 0 | did u check a system keybad ic? did u check a cobba? u can say that yr phone is totaly dead so 1- check if u have a short on system keybad IC 2- remove cobba and power on if it damaged u well see contact service in yr screen 3- check ccont (reballing or chang) 4- check power cristal 5- check a transistor beside power cristal 6-check flash IC and ram 7-yr mad thats all |
write flash checksum OK....But phone is dead | amol_sm | Universalbox | 7 | 06-12-2009 22:22 |
unlocked sonyz200, but phone is dead? | mustangmoto | Sony Ericsson | 3 | 09-13-2004 00:01 |
N3310, vibra & LEDs are on when connect battery, but phone is dead | MaRiN | Nokia Hardware & Hardware Repair | 2 | 02-19-2003 20:45 |
