Old 03-07-2008, 05:50   #1 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
::N70 power Only with charger::
Nokia N70 Power On Only with charger,Without Charger it takes some amperes with Power Supply,But not power On:Swtich have 3.7 volts on its one lag.any idea waht is wrong.
Old 03-07-2008, 06:03   #2 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
do you try to change power switch?
Old 03-07-2008, 06:27   #3 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
First Boot Not ok without charger,with charger i take UFS HWK log,Here it is:
1ST BOOT  : C0,0C [Rm-1]
OMAP ID   : 17100701
OMAP MODE : 00
OMAP PBID : 968E9BCC86A32D334A651B12E2C888FD062F3E4D
OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
OMAP ROID : AB5E4ADB27A06946
RAPx ID   : 000000010000022600010006000C192101002200
EM 1 ID   : 00000232
EM 2 ID   : 00000352
RAPx PBID : 0FB00011FE7E4E510E9963113C1E314EF3F5CFC0
RAPx MODE : 00
RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
RAPx ROID : F28A211FCEA7B19D
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0
CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO  : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
CMT VPP   : Internal
CMT ALG Boot OK
APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0
APE FLID0 : 00EC0036-00A500C0, Sam KAL00R00EB
APE RQALG : OMAP1610 GBBM-1.8.1 ALG
APE FLCNT : 01010000020000000600000000000000000000
APE 2ND Boot OK
APE ALG0  : h3_sam_nand_gbbm.fg, Ver: 1.33.0
APE VPP   : Internal
APE KSIG1 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
APE ALG Boot OK
Rebooting Mobile
MCU Sw: V 05wk07v41 08-02-06 RM-84 (c) Nokia.
APE Co: V 5.0609.2.0.1 01-03-06 RM-84 (C)Nokia
APE Va: 5.0609.2.0.1-Arabic 01-03-06 RM-84 (c)Nokia.
Prd.Cd: 0524109
Bpr.Cd: 0522156
Pro.Sn: CPD554983
HW    : 6061
APE Hw: 256
APE Ad: 16053
RETU  : 32
TAHVO : 52
RFIC  : 150a160f
DSP   : rolf_05wk07v24
LCD   : 2727964
IMEI  : 351862-01-933815-9
SLserv: SIMLOCK SERVER VERSION 58
SLconf: 244-07-00000000000
SLstat: 0000000000000000
SL_Cnt: 00 00
Provider: Nokia Test;Finland
Attachment Have Screen Shot of Self TeST Result with HWK:
Old 03-07-2008, 06:36   #4 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
correct u change switch 2, check track from retu (e,12) if all ok change retu problem must rectified
tested 100%
SP
Old 03-07-2008, 07:01   #5 (permalink)
Member: 142486
Thanks Meter: 8
can u help me finding ways for my n6101, display , if u turn it on white screen 4 a while' then gone....but top lcd is ok only the main doesnt work, i have change the top board including lcds bnut still the same, change the flex and its still the same, so it will be in the main board and cant find the solution 4 it..
Old 03-07-2008, 07:48   #6 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
try to resold the battery terminals
Old 03-07-2008, 08:04   #7 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
ok,i will check and will post the result.....
6630 power on only with fbus..with battery no power no charger monte1987 Nokia Hardware & Hardware Repair 8 12-01-2010 17:38
e50 power only with box crazytel Nokia Base Band 5 ( BB-5 ) 0 04-15-2009 23:08
3220 power only withe ufs visionmaster20 Nokia Hardware & Hardware Repair 5 03-15-2008 09:40
BB5 phones powers only with modified cable problem skydreas Nokia Base Band 5 ( BB-5 ) 0 04-12-2007 09:43
gx10 power only with charg mory2 Sharp 0 09-17-2005 22:07
Page generated in 0.21309 seconds with 10 queries
