Old 06-07-2007, 21:30   #1 (permalink)
Member: 186541
6630 power on only with fbus..with battery no power no charger
hi..i have one 6630 that works so fine if i connect to fbus and jaf..but not charger and not power on with battery..i read same problem for a 6680 but i don't found topic..help me with a schematic..
Old 06-09-2007, 16:37   #2 (permalink)
Member: 186541
any solution??thanks
Old 06-10-2007, 08:01   #3 (permalink)
Crazy Poster
Member: 79745
Thanks Meter: 27
[IMG]C:\Documents and Settings\ETC.ETC-A97E62A35B4\Desktop\downloads\REPAIR-SOLUTION PIC\6630%20charging%20ok%20but%20not%20power%20on. jpg[/IMG]
Old 06-10-2007, 08:06   #4 (permalink)
qayyoom1's Avatar
Member: 385787
Thanks Meter: 17
here is solution
plz check and post reply
File Type: jpg 6630%20charging%20ok%20but%20not%20power%20on.jpg (69.5 KB, 208 views)
Old 06-10-2007, 14:41   #5 (permalink)
Member: 256214
Thanks Meter: 10
yes DEADSURE it will work i had used it before so if you dont want make a jumper so change it
Old 06-12-2007, 23:39   #6 (permalink)
AYMAN SHAMAYLH's Avatar
Member: 146798
Sonork: 100.1576177
Thanks Meter: 24
i have same problem i do like that jumber
but still not working with battery
working fine on box
changed tahvo
changed retu
flashing
all same problem still
if i connect to power suply i can turn it on off using power switch
any help pls
Old 06-13-2007, 15:22   #7 (permalink)
Member: 172811
Thanks Meter: 135
Check The Battery Connectors Specially The Gnd Pin.
Old 06-13-2007, 15:31   #8 (permalink)
.::intel32::.'s Avatar
Member: 350719
Sonork: 100.1623850
Thanks Meter: 153
6630
check BSI line
Old 12-01-2010, 17:38   #9 (permalink)
Member: 1379392
Thanks Meter: 10
Sir show me the bsi line jumper its damage from the battary connector its insert sim prob.
5800 Nokia cant power on only with Fbus cable omarroud Cyclonebox 0 02-15-2010 16:44
6310 powers on only with power supply unit not with battery kwikcell Nokia Hardware & Hardware Repair 0 01-19-2009 22:37
T230 power on only on charger, but then works ok woithout charger MaRiN Sony Ericsson Hardware Repair 4 09-30-2004 21:04
5110, powers on only with charger conected !!! mr_x4you Nokia Hardware & Hardware Repair 2 12-23-2001 19:31
5110, powers on only with charger conected !!! mr_x4you Nokia Hardware & Hardware Repair 1 12-13-2001 13:33
Page generated in 0.21568 seconds with 10 queries
