Old 03-17-2006, 15:37   #1 (permalink)
Crazy Poster
Member: 64349
Thanks Meter: 7
N70 Power Switch No Solution
Hi Friends
frist Sorry 4 my English
i have N70 cant get power switch track
the phone is power on in the box only
but from switch key no way
frist tryed to flash phone i know it not effected
sec go to hardware sol
get pdf for n70 and get the track but not working
and this is the pic for the track i need sol for this is problem
this is track is wrong
i need true track
many thankes
br Mohamed Nabil
[email protected]
www.gsm4arab.net
0020105083050
The Following 4 Users Say Thank You to GsmEgypt For This Useful Post:
Old 03-19-2006, 22:35   #2 (permalink)
Member: 52847
Thanks Meter: 73
no body here
Old 06-06-2006, 17:38   #3 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
i have same problem and iam now trying to slove it
Old 06-06-2006, 20:25   #4 (permalink)
Member: 70463
Thanks Meter: 6
yes thesame problem also for me 2 units of n70 failure to power on,but in the cable it is good and shows nokia logo and can reset settings.
l go to hardware and trace the wiring the wiring from switch to retu or power ic is good also.l replace power ic theasame problem also failure to power on.l guest l thought that this is like 6680 6630 that the track is going to a driver so l also jumper it by a piece of wire just curriousity but still not working.lm now remove the retu and try to combine it with other 6680 6630 phone just to now how the ic work.l post some info just in case lm successful.
Old 06-06-2006, 21:50   #5 (permalink)
KARAMAT's Avatar
Member: 51609
Thanks Meter: 6
look at attachment
remove that crestal in blue color and short the pin ander it just like red line
and from the right side connect it directly to power switch
this will solve ur problem
if not u will nead to take it from under retu directly to power switch
it's so easy as it from the first line under retu
The Following 4 Users Say Thank You to KARAMAT For This Useful Post:
Old 06-06-2006, 22:32   #6 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
The power key is diretly connected to Retu ic try to rehot Retu IC
The Following 3 Users Say Thank You to KHJAMAL For This Useful Post:
Old 06-24-2006, 01:05   #7 (permalink)
Registered User
MAGDY2's Avatar
Member: 49677
Thanks Meter: 53
Karamat
Tnx Man
Old 07-05-2006, 14:29   #8 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
i will try your diagram solutions.i will just give my remarks the next time i log in.
Old 07-05-2006, 17:20   #9 (permalink)
Member: 143156
Thanks Meter: 95
thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaankxxxxx
Old 07-05-2006, 23:28   #10 (permalink)
Registered User
Member: 86890
Thanks Meter: 9
after reheating the retu Ic phones now power on perfectly. good diagram anyway
Old 06-09-2007, 09:31   #11 (permalink)
Member: 516696
what are the exact jumper configuration of power switch of N70
plz help
Old 06-09-2007, 10:36   #12 (permalink)
markrhi's Avatar
Member: 520956
Thanks Meter: 12
bro, how about white screen only n70 also...doesnt off.
Old 06-09-2007, 11:15   #13 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear brother check it
The Following 3 Users Say Thank You to meo786pk For This Useful Post:
Old 06-09-2007, 12:11   #14 (permalink)
Member: 83575
i the power switch track
change the cristal ic behaind the lcd ic worked 100/100
Old 06-09-2007, 17:27   #15 (permalink)
Member: 12302
Thanks Meter: 22
Pls change the ESD filter (backup battery top side). You are confused then pls check the attachments
The Following 3 Users Say Thank You to gopidas For This Useful Post:
N70 power switch way ham_sang Nokia Hardware & Hardware Repair 6 08-03-2010 01:53
1200 flash ok ui setting ok normal mode ok but not no by power switch switch volt ok Punit Kumar Nokia Digital Core Technology 4 ( DCT-4 ) 7 02-25-2010 12:58
n70 power switch last solution here! reji Nokia Hardware & Hardware Repair 13 12-31-2009 10:11
n70 dead after changing power switch, no pwr, no charge! DjDecibel Nokia Hardware & Hardware Repair 6 07-24-2009 10:31
3310,8210 Power switch solution. 6610 volume switch solution(NEED HELP) smartfone Nokia Hardware & Hardware Repair 7 09-15-2006 06:29
Page generated in 0.23919 seconds with 10 queries
